6597 Discussions
when I run python3 stream_infer.py ,The result is scintillating, Correct and Nan alternatly
When I'm on the raspberry Pie 3,and run python3 stream_infer.py.I can get the result, But the result is scintillating, Correct and Nan alternatly and endless.,I dont know why ,Is there a problem with my script stream_infer.py, and what does the file have to modify?
@tiandixing Try the following:
  1. Make sure you are using the latest version of the NCSDK (1.12) on the host machine. The latest SDK can be found at https://ncsforum.movidius.com/discussion/98/latest-version-movidius-neural-compute-sdk#latest.
  2.
  3. Rebuild the graph file on your host machine using mvNCCompile after you upgrade to NCSDK version 1.12.
  4.
  5. Rebuild the API on the Raspberry Pi.
  6.
  7. Run stream_infer.py again.
  8.
Let me know if this works for you.
