Intel® Edge Software Hub
Get answers from community peers to your questions about building Edge Software Hub solutions for edge compute node.
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
413 Discussions
[Celeron N5105]How do I install Intel® ESDQ on a product with the N5105 CPU?
YYTCharlesChen
Hi There,
I want to install Intel® ESDQ in my Intel development board. But the installation keeps failing.
Installation environment:
-------------------SYSTEM INFO--------------------
Package Name: Intel Video AI Box 3.0
Product Name: youyeetoo X1 SBC
CPU SKU: Intel(R) Celeron(R) N5105 @ 2.00GHz
Memory Size: 8 GB
Operating System: Ubuntu 22.04.3 LTS
Kernel Version: 6.2.0-39-generic
Accelerator: None
CPU Utilization: 0.9%
Available Disk Space: 128GB
I've uploaded a screenshot of the error report.
How can I solve this problem?
Thank you.
Iffa_Intel
For information on specific Intel® ESDQ Test Packages or to Configure & Download Intel® ESDQ Test Packages, follow the links below :
Note that those links support the latest Intel ESDQ version 11.0.0
Make sure you are referring and installing according to the latest version.
Once you are done configuring & downloading the package, refer to this Get Started Guide for steps to perform on the target system.
Ensure that you had downloaded and installed Intel ESDQ with the respective test modules before you continue in this section.
Cordially,
iffa
YYTCharlesChen
Dear Iffa,
Yes.
I am using the latest version 11. Refer to this Get Started Guide for steps to perform on the target system.
During installation, enter the product key you received when downloading the package. When the installation is complete, you see the message Installation of package complete and the installation status for each module.
NOTE: Ensure all the modules are installed successfully before using Intel® ESDQ. If any modules fail to install, run the command: ./edgesoftware update <Failed Module ID(s)>
According to this instruction, many attempts were made with the same error (screenshot provided in previous attachment).
Can you please help me to confirm if N5105 is using Intel ESDQ?
If so, please let me know what information I need to provide to you in order to solve my problem?
Iffa_Intel
Generally, these hardware are officially validated to support Intel ESDQ:
  • 11th, 12th, or 13th generation Embedded Intel® Core™ processors
  • 12th generation Intel® Core™ Desktop processors with Intel® Arc™ A380 Graphics
  • Intel Atom® Processor X Series, (formerly Alder Lake-N)
  • Intel® Processor N-series (formerly Alder Lake-N)
 You are using an Intel® Celeron® Processor N Series (Products formerly Jasper Lake) which is a newer N series processor.
Could you share your log files directory: /var/log/esb-cli/<ESH-package-name>
Your first photo (AVX error) is a known issue where Celeron® processors being used do not support AVX instructions.
You may refer to this article.
Cordially,
Iffa
YYTCharlesChen
Hi Iffa,
Please check the log file.
I checked the AVX solution, can I use the TensorFlow library without AVX enabled?
Can I complete ESDQ certification if the N5105 does not support AVX commands?
thank you for your help.
Iffa_Intel
After getting some clarifications, the ESH package installation should be successful with or without AVX.
Once the ESDQ tests modules run, we will know which components require AVX instruction set.
Please help to check whether you have the correct permissions to run docker containers without sudo access. Linux post-installation steps for Docker Engine | Docker Docs
In addition to that, there is a new package release version 3.1. Could you try to install this version and see whether the same issue persist in your system?: Intel® Edge Software Device Qualification (Intel® ESDQ) for Intel®...
Cordially,
Iffa
YYTCharlesChen
Thank you.
I will try the 3.1 version.
BTW, can you provide an already optimized system image like Ubuntu for Intel?
https://ubuntu.com/download/iot/intel-iot
A device that meets the requirements, downloads your test system and does not have to think about the environment.
Iffa_Intel
You should be able to use that image (latest version) that you shared where it should fulfill the ESDQ system requirements.
Note:
Choose Optimised Real-time Ubuntu Intel Atom® X7000E Series Processors (former codename Alder Lake N) on the image link you shared.
ESDQ Target System Requirements
  • Operating System:
    • Ubuntu* 22.04.2 or higher
  • At least 80 GB of disk space
  • At least 8 GB of memory
  • Direct Internet access
Cordially,
Iffa
YYTCharlesChen
Hi Iffa,
Still not successfully installed.
I've attached the log of the failed installation to the question.
1. bmra_container_base > test_gpu error
2. ffmpeg > Conversion failed!
3. AIBOX:FAILED:
resnet-50-tf
ssdlite_mobilenet_v2
yolo-v3-tiny-tf
yolo-v4-tf
efficientnet-b0
yolo-v3-tf
Best Regards
Iffa_Intel
any chance that you tried the ESDQ CLI?
Perhaps that would work for you.
Cordially,
Iffa
Iffa_Intel
In addition to that, we are furthering our investigation regarding this issue
Cordially,
Iffa
Iffa_Intel
after further investigation, it is confirmed that Celeron is not supported by this software package.
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
