Intel® Edge Software Hub
Get help on building Edge Software Hub solutions for edge compute node
Welcome to the Intel Community! If you like the answer to your question, please mark it as 'Accepted Solution' to help others.
The Edge Software Vision Package for Red Hat Enterprise Linux is now available here.
Learn more about developing on Intel® Hardware and Software here.
315 Discussions
Install Edge Insights for Industrial error:eii2.6_changesource. sh
xunaichao
Executive program installation (./edgesoftware install)
The error message:Failed to install eii_installer. [Errno 8] Exec format error: './EII2.6_changesource.sh'
Exiting Installation. Failed to find manifest file edgesoftware_configuration.xml. Check the file location and run the command from the folder where the file is located.
xunaichao
Run the./edgesoftware install command to download the eii2.6_changesource. sh
Sahira_Intel
Can you confirm what OS you are running? EII is compatible on Ubuntu 18.04.3 - see software/hardware requirements here
Sincerely,
Sahira
xunaichao
Hello,Sahira_Intel
Version information
xunaichao
Trying to install  18.04.3
xunaichao
Hi,Sahira_Intel.
I uploaded the log
Log path(output.log)/var/log/esb-cli/Edge_Insights_for_Industrial_2.6.2
Log path(install.log): /var/log/esb-cli/Edge_Insights_for_Industrial_2.6.2/eii_installer
Sahira_Intel
Thank you for attaching log files. I am currently looking into this
Sincerely,
Sahira
xunaichao
Today I tried to reinstall and eii2.6_changesource. Sh is working fine
But a new error was encountered
Eii_installer log
Sahira_Intel
It looks like this was an intermittent issue affecting users in your location.
Please try again and let me know if installation was successful.
Sincerely,
Sahira
