Application Crash: Illegal instruction
Hi there,
I tried to run embree as well and it does not work (application crashes). Tested with Windows Compiler 32 and 64 Bit Version.. Running Win 7 (64 Bit) with Visual Studio 2010.
This might help (Crash Report - German Win 7 Version):
Fehlermodulname:	embree.exe
Fehlermodulversion:	0.0.0.0
Fehlermodulzeitstempel:	4e10c935
Ausnahmecode:	c000001d
Ausnahmeoffset:	0000000000057b7f
  Betriebsystemversion:	6.1.7600.2.0.0.256.48
  Gebietsschema-ID:	1031
  Zusatzinformation 1:	1f07
  Zusatzinformation 2:	1f07b9a70824c87fb638e94e8bb5c69f
  Zusatzinformation 3:	7f61
  Zusatzinformation 4:	7f61147635beb36958b7bedc38e0f914
I tried some options (-c with .ecs, -i with .obj.. writing to file.. the regression test) and nothing seems to work correctly. The regression test just opens a blank (white) window, does some calculations (CPU usage) and then terminates (window is closed) without any result.
Tried to remove the__SSE4_2__ - define as well, leading to compilation errors.
Any ideas? Thanks ;)
We'll fix thisfor the final release.
"We'll fix thisfor the final release."
My lastpostreferred to the "runs only on Windows 7" comment. The "__SSE4_2__" issue is more tricky, becausewith theVS2010 compilerwe cannot figure out atcompile time which instruction sets are supported by the system CPU. If someone has a nice solution for this, we'd appreciate to learn about it.
My CPU is kind of old: Core 2 Duo E6550 @ 2,33 GHz - gonna try it on an i5 soon.
Would it help anything to try compiling with VS 2008 ? Just asking cause I could download it via MSDNAA...
I started the debugging with the following result:
Exception Message: Unhandled Exception at 0x000000013fb67b7f in embree.exe: 0xC000001D: Illegal Instruction.
Occured in: object_pinning.cpp (rtcore/common)
At Line: 46
/*! map even and odd primitive to bin */
 Box prim0 = prims[start()+i+0]; ssei bin0 = getBin(prim0);
       Box prim1 = prims[start()+i+1]; ssei bin1 = getBin(prim1);   <----- Exception in this line
Pressing "continue" only leads to the next exception in the same code line due to the for loop..
#define _mm_blendv_ps __emu_mm_blendv_ps
#define _mm_blend_ps __emu_mm_blend_ps
#define _mm_blendv_epi8 __emu_mm_blendv_epi8
#define _mm_mullo_epi32 __emu_mm_mullo_epi32
#define _mm_min_epi32 __emu_mm_min_epi32
#define _mm_max_epi32 __emu_mm_max_epi32
#define _mm_extract_epi32 __emu_mm_extract_epi32
#define _mm_insert_epi32 __emu_mm_insert_epi32
#define _mm_extract_ps __emu_mm_extract_ps
#define _mm_insert_ps __emu_mm_insert_ps
#define _mm_round_ps __emu_mm_round_ps
#define _mm_insert_epi64 __emu_mm_insert_epi64
#define _mm_extract_epi64 __emu_mm_extract_epi64
