Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
288 Discussions
BVH's memory consumption is not adjusted at the end of the build
Yvain_Raeymaekers
I am using Embree under Windows and I have noticed that the displayedevaluation of the memory consumption of the BVH did not match its actual size in memory.
Digging a bit deeper, I have found that the implementation of the functionalignedRealloc() of platform.cpp did not do anything (it just returns the pointer).
So the BVH's memory footprint is not reduced at the end of the build as it is supposed to.
Why did you not use the win32 function _aligned_malloc() for its implementation. Is there something wrong with it or is it just an omission ?
SvenW_Intel
You are right, the _aligned_malloc, _aligned_realloc, _aligned_free functions, are the better choice. We will fix this in an update.
SergeyKostrov
Valued Contributor II
>>...Why did you not use the win32 function _aligned_malloc() for its implementation...
Itis not a Win32 API function.
It is a CRT-function and, in case of a Visual Studio 20xx,it "unwraps" to _mm_malloc().
#define _mm_malloc(a, b) _aligned_malloc(a, b)
Note: CRT- C Run-Time
