Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
288 Discussions
Clarification on RTC_GEOMETRY_TYPE_FLAT_LINEAR_CURVE "u" value.
AndrewC
New Contributor III
The documentation says "The intersection with the curve segment stores the parametric hit location
along the curve segment as u-coordinate (range 0 to +1)."
As linear curves are represented as cylindrical segments, then a ray will intersect the cylinder in two places. Is the point represented by "u"  the closest point of the "ray" to the line? Or is the projection of the 'first' intersection of the ray with the cylinder onto the line?
SvenW_Intel
It is the u-value of the closest point on the line to the ray.
SvenW_Intel
