Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
288 Discussions
Error: failed loading library "device_singleray"
More__Om
I have an issue with https://embree.github.io/renderer.html. I tried the binnarie and from sources, I build with vs 2017, x64, Release, the dll is in the folder, I checked the path with debugger.
Do you have any idea?
Thank you.
BenthinC_Intel
Hi Julien,
the Embree renderer has been obsolete and unsupported for a couple of years now. If you need an example renderer have a look at the "pathtracer" included in the tutorials, which comes with every Embree release.
More__Om
Ok,thank you,
I was about to do that.
Have a good day
