Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
Reflection and refraction
uminokaze
Hi all,
This might a a dumb question so bare with me :D. Does embree support reflection and refraction? I tried to turn it on through the .mtl file but doesn't seem to work.
Thanks for the helps
Manfred_Ernst__Intel
Yes, Embree supports reflection and refraction, if you use XML+BIN to describe your scene (example: crown), or if you use the API directly. OBJ+MTL does not support reflection/refraction.
uminokaze
oh ok, thx a lot
