Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
Run in Windows XP
wachel
Hi,all guys
sorry for my bad english :)
I found embree is very very fast ,but it can not work on WindowsXP,I found a way to run the embree on WinXP ,only modify two source file,hope this can help you
1: condition.cpp,disable the "Condition Variable"(i found the code from the url:http://yats.googlecode.com/svn-history/r74/trunk/src/sys/condition.cpp)
2: sse.h,use "smmintrin_emu.h" instead ""
it works well on my computer
boobam
Hi wachel,
I am ignorant of programming and writing code.
I would like to run Embree on Win XP 64 bit, in 3D Studio Max 2012.
I have Vray2.3 installed.
I found where to add your attachments to replace originals in the Source code.
What do I do next?
Thank you,
BooBam
