Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
288 Discussions
UV encoding while sampling a Subdivision Mesh object?
David_B_3
Please I would like to know how are we supposed to generate the u,v coordinates when generating samples for a Subdivision Mesh object.
There are algorithms to generate stratified samples for triangles and quads, but Embree Subdivision Mesh objects use special encoded u,v coordinates. When a ray hits a Subdivision Mesh, the ray u,v coordinates are already encoded and ready to be used in rtcInterpolate, but how can I manually generate stratified u,v coordinates myself that are correctly encoded to be used with rtcInterpolate in a subdivision mesh?
Also, as now there is a new Embree v3-beta0 with a different API I would please like to know whether there is a different way to do this in Embree v3?
Thanks and best regards!
SvenW_Intel
For quadrilateral faces the UV encoding is standard. For other faces (e.g. triangles), the subdivision surfaces section of the API describes the decoding of the UV coordinates:
const unsigned int l = floorf(0.5f*U);
const unsigned int h = floorf(0.5f*V);
const unsigned int i = 4*h+l;
const float u = 2.0f*fracf(0.5f*U)-0.5f;
const float v = 2.0f*fracf(0.5f*V)-0.5f;
Here i, is the i'th quadrilateral you get when doing a Catmull Clark subdivision step and u/v are the local hit coordinates of this quadrilateral. This encoding did not change with Embree 3.
Note that the 3 quadrilateral you get after subdividing a triangle using the Catmull Clark rules have same area. Thus you can just uniformly sample a random quadrilateral i, and then uniformly sample the local u/v coordinates. Then you need to invert the above decoding to encode the uv's and pass them to rtcInterpolate:
const unsigned int h = (i >>2) & 3;
const unsigned int l = i & 3;
const float U = 2.0f*l + 0.5f*u;
const float V = 2.0f*h + 0.5f*v;
David_B_3
Hello, Sven.
That's great, thank you very much, I will try that! :-)
