Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
Were is the problem?
zineddine62
Hi, I compile this source code in Visual Studio 2008: http://software.intel.com/file/39968, these are simple scenes of embr, I got a folder after compilation, so the link below
http://www.mediafire.com/?5tyjy1deuj1zycf
it does not work in Windows XP and Windows 7? Were is the problem?
SvenW_Intel
As described in the documentation, copy the freeflut.dll from the embree/app/freeglut/Win32 folder into your embree/Win32 folder to run Embree.
zineddine62
thank you for your response, I must do, copy freeglut.dl it into embre/Win32 folder and double-click in embr. exe file, a window black like DOS opens and suddenly disappears!
in win7 well sure
SvenW_Intel
Best start Embree from a shell, e.g. through a command line like this:
embree.exe -c ..\..\models\cornell_box.ecs
zineddine62
Thank you very much Sven Woop, I solved the problem, but I can run it in embre beata Release only , precompiled , I think is an amazing rendering ,very fast
