Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
-help
riftmaster
i hope this is in the right place......
i have a working, compiled version of embree on windows. However when i run the 'embree -help' commanda cmdwindow pops up and then disappears, too quickly to read.
Any Help?
thanks,
riftmaster
SvenW_Intel
Maybe you are running embree from within Visual Studio? Then the command window might disappear.
Start Embree from a shell. Unfortunately, there is a little bug where Embree starts to render when you use -help, simply press ESC to stop it.
Alternatively, you can also find the output of -help in the app/embree.cpp file.
riftmaster
Thanks for replying, i am running it from a compiled version found here: http://graphicall.org/415
the other commands work without a problem.I still cannot get it to work, but have read it from embree.cpp
thanks again,
riftmaster
