Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
288 Discussions
intersection test with increased tolerance
Lee__Heungson
I am trying to test collision detection by using embree. For this configuration I need more flexible intersection test (meaning larger epsilon) for triangle meshes.
For example, if I consider a triangle with following vertices (v0, v1, v2)
v0.x = 0.; v0.y = 0.; v0.z = 0.;
v1.x = 0.; v1.y = 100.; v1.z = 0.;
v2.x = 100.; v2.y = 100.; v2.z = 100.;
and the ray with
org.x = -eps; org.y = 0.; org.z = -10.;
dir.x = 0.; dir.y = 0.; dir.z = 1.;
where (eps > default eps)
The ray won't intersect the triangle.
And I found this article and applied what this comment suggested
https://software.intel.com/en-us/forums/embree-photo-realistic-ray-tracing-kernels/topic/755654#comment-1918389
For some test cases it worked fine
but for the other cases it didn't work because
it was not able to pass node intersection test before actually going into triangle intersection test.
For a single ray test, I guess it has something to do with this part of the code in  node_intersector1.h
template<int N, int Nx>
      __forceinline size_t intersectNodeRobust(const typename BVHN<N>::AlignedNode* node, const TravRay<N,Nx,true>& ray, vfloat<Nx>& dist)
      const vfloat<N> tNearX = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.nearX)) - ray.org.x) * ray.rdir_near.x;
      const vfloat<N> tNearY = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.nearY)) - ray.org.y) * ray.rdir_near.y;
      const vfloat<N> tNearZ = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.nearZ)) - ray.org.z) * ray.rdir_near.z;
      const vfloat<N> tFarX  = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.farX )) - ray.org.x) * ray.rdir_far.x;
      const vfloat<N> tFarY  = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.farY )) - ray.org.y) * ray.rdir_far.y;
      const vfloat<N> tFarZ  = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.farZ )) - ray.org.z) * ray.rdir_far.z;
      const vfloat<N> tNear = max(tNearX,tNearY,tNearZ,ray.tnear);
      const vfloat<N> tFar  = min(tFarX ,tFarY ,tFarZ ,ray.tfar);
      const vbool<N> vmask = tNear <= tFar;
      const size_t mask = movemask(vmask);
      dist = tNear;
      return mask;
The problem is that I have no idea what this code means.
My question is
1. Can I modify the way intersection test works with bounding volumes?
2. if 1 is not possible, can I modify the way bounding volumes are created?
If the above are not good idea, I'll try user geometry.
Please help me.
Lee__Heungson
I am self-answering my question. I modified the above intersection test with
      const vfloat4 eps_x = float(ulp) * (vfloat4::load((float*)((const char*)&node->lower_x + ray.farX)) - vfloat4::load((float*)((const char*)&node->lower_x + ray.nearX)));
      const vfloat4 eps_y = float(ulp) * (vfloat4::load((float*)((const char*)&node->lower_x + ray.farY)) - vfloat4::load((float*)((const char*)&node->lower_x + ray.nearY)));
      const vfloat4 eps_z = float(ulp) * (vfloat4::load((float*)((const char*)&node->lower_x + ray.farZ)) - vfloat4::load((float*)((const char*)&node->lower_x + ray.nearZ)));
      const vfloat<N> tNearX = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.nearX)) - eps_x - ray.org.x) * ray.rdir_near.x;
      const vfloat<N> tNearY = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.nearY)) - eps_y - ray.org.y) * ray.rdir_near.y;
      const vfloat<N> tNearZ = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.nearZ)) - eps_z - ray.org.z) * ray.rdir_near.z;
      const vfloat<N> tFarX  = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.farX )) + eps_x - ray.org.x) * ray.rdir_far.x;
      const vfloat<N> tFarY  = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.farY )) + eps_y - ray.org.y) * ray.rdir_far.y;
      const vfloat<N> tFarZ  = (vfloat<N>::load((float*)((const char*)&node->lower_x+ray.farZ )) + eps_z - ray.org.z) * ray.rdir_far.z;
with the following change in contants.h
struct UlpTy
    __forceinline operator double( ) const { return std::numeric_limits<double>::epsilon(); }
    __forceinline operator float ( ) const { return float(1.e-3); }
I am testing this even though I am not sure what kind of side effects these change will cause.
BenthinC_Intel
If you really need larger epsilons during BVH traversal it might be easier to adjust the final tNear, tFar values instead of each dimension individually. However, BVH traversal in robust mode is already conservative in the node intersection test, so I'm just wondering why you need even larger epsilons?
Lee__Heungson
Thanks for the idea.
Speaking of your question I assume you mean "conservative" as a ray not missing some triangles. In my application which is a sort a contact algorithm of the finite element analysis, when the ray almost hit the boundary of a surface but technically didn't intersect it, it should still be treated as intersected. Because the nonlinear equation solver becomes unstable when the small changes in the solution vector cause jumps of contact forces between two value (0 to 1 or 1 to 0) in consecutive iterations.
