Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
288 Discussions
is there a possibility to get : Bin , XML ,ECS Files ..?
zineddine62
hi ..
Can you explain more ,is there a possibility to export scene from max to use as embre !!
SvenW_Intel
Sorry, but there is no tool to export the Embree XML file format from Max. For more information about the XML file please look into the app/importers/xml.cpp source file.
You can export the OBJ format from Max and load these files into Embree. However, not all features are supported this way. For instance, light sources have to be set via the command line when choosing this approach. For command line options see embree -h
