Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
rtcCommit not working
ritwik_d_
Below is the code that I am using, my code gets stuck at rtcCommit(). I am not sure why this is happening...any clue would be great help.
geomID = rtcNewTriangleMesh(Scene, RTC_GEOMETRY_STATIC, nTriangles, embVertices.size(), 1);
    EmbVertex* vertices = (EmbVertex*) rtcMapBuffer(Scene, geomID, RTC_VERTEX_BUFFER);
    for(unsigned int i = 0; i < embVertices.size(); i++)
        vertices.x = embVertices.x;
        vertices.y = embVertices.y;
        vertices.z = embVertices.z;
    rtcUnmapBuffer(Scene, geomID, RTC_VERTEX_BUFFER);
    cout<<"\nCompleted mapping vertices.\n";
    EmbTriangle* triangles = (EmbTriangle*) rtcMapBuffer(Scene, geomID, RTC_INDEX_BUFFER);
    int t = 0;
    for(unsigned int i = 0; i < Triangles.size(); i++)
        if(valid)
            triangles.v0 = Triangles.v0;
            triangles.v1 = Triangles.v1;
            triangles.v2 = Triangles.v2;
            embTriangles.push_back(Triangles);
            t++;
    rtcUnmapBuffer(Scene, geomID, RTC_INDEX_BUFFER);
    cout<<"\nCompleted mapping triangles.\n";
    rtcCommit(Scene);
ritwik_d_
This is the message I get from Embree:
Embree Ray Tracing Kernels 2.3 (Jun 11 2014)
  Compiler : Visual C++ Compiler 17.00.6103.0
  Platform : Windows (32bit)
  CPU      : SSE SSE2 SSE3 SSSE3 SSE41 SSE42 POPCNT AVX F16C RDRAND AVX2 FMA3 LZ
CNT BMI1 BMI2
  Features : intersection_filter bufferstride
  WARNING: enabled 'intersection filter' support will reduce hybrid traversal pe
rformance
Embree: Unknown error, (cannot create thread)
I do not understand why it cannot create the threads
SvenW_Intel
Do the tutorials run? e.g. ./tutorial00 -rtcore verbose=2
ritwik_d_
yes tutorials are running fine.
SvenW_Intel
Sorry but I have no idea why the CreateThreads function fails. Look at the CreateThreads call in file embree/common/sys/thread.cpp, maybe you can find the problem there. Also, try to figure out what you do different than the tutorials.
ritwik_d_
What is a good place to do rtcInit()?
Is it possible to do this inside a constructor of a class and then call rtcExit() inside the destructor?
SvenW_Intel
You can call rtcInit and rtcExit in a constructor and destructor of a class. However, you should not call rtcInit from the constructor of a global variable, thus please create the class either with new or on the stack.
ritwik_d_
I am actually creating the class object with new but this is a global variable, the reason for that is I am using OpenGL to display the scene geometry and so the callback functions can access the class object. What is the reason for rtcInit() to not work on global variables?
Ondra_K_
Because that way the rcInit could be called before initialization of global variables inside embree library
