Intel® Embree Ray Tracing Kernels
Discussion forum on the open source ray tracing kernels for fast photo-realistic rendering on Intel® CPU(s)
tutorial.lib missing
Lawrence_S_
Dear all. I have recently downloaded embree. I compile with the cmake gui and everything appears to go well. When I open the vxproj for one of the tutorials and try and build it it complains that ../../Debug/embree.lib is not found. I managed to find a copy of this file somewhere and copy it into the appropriate directory. However after that it complains ../../Debug/tutorial.lib cannot be found. I cannot find a copy of this library anywhere. I'm on a windows x64 machine. Has anybody elese had this issue. If anybody has a copy of a file called tutorial.lib that would be much appreciated also.
SvenW_Intel
Could you try to generate the solution file with CMake, then open and build the solution using Visual Studio.
