Intel® Enpirion® Power Solutions
Interact with Intel® product support specialists on Intel® Enpirion® DC-DC Step-Down Power Converters
This forum offers only peer-to-peer support. Thank you!
230 Discussions
MotherBoard DH61CR ACPI S3 State
BillyMaciel07
My computer has an Intel motherboard model DH61CR. The computer went into hibernation mode and will no longer turn on. There is an LED on the motherboard indicating that it is in Standby mode. Any tips or help to resolve this issue? Thank you all !
Labels (3)
leestanton
It sounds like your computer might be stuck in standby or hibernation mode. Here's what you can try:
  1. Power Cycle: Unplug the power cord, press and hold the power button for 10-15 seconds to discharge any residual power, then plug it back in and try turning it on.
  2. Check Power Supply: Ensure the power supply is working properly by testing with another power cable or outlet.
  3. Reset CMOS: Remove the CMOS battery from the motherboard for a few minutes, then reinstall it. This will reset the BIOS settings and may resolve the issue.
  4. Reseat Components: Remove and reinsert RAM and other components to ensure a proper connection.
If these steps don't work, there could be a deeper hardware issue requiring professional diagnosis.
AlHill
@leestanton   ChatGPT answers really do not work.
[If you find any Intel driver you might need, download and save it now.]
