10.1 Install Failure - IDE.MSI
John_L_4
I was trying to install IVF 10.1.013 after uninstalling 10.0.027 and deleting all of the old installation stuff in the C:Program FilesIntelDownload folder.
Everything was fine until it tried to install the Visual Studio Integrations and it couldn't find IDE.MSI because it was looking for it in the old Fortran91 install folder that I had deleted.
What is that? Why would I have to have kept a 9.1 install folder to install 10.1.013 cleanly?
John
My guess is that you had 9.1 IDE support installed, or partially installed, and deleting the download folder caused problems for the uninstall, though I'm not completely sure why that should be.
If this continues to give you problems, download and install the Windows Installer Cleanup Utility and use it to remove any "Intel Fortran Integration into Visual Studio" it shows, then try installing again.
