Hi: We upgraded to XE 2013 SP 1 and our main code now crashes when trying to access an allocatable array. The array was apparently not allocated successfully even though the STAT variable (as in ALLOCATE( array(12), STAT=ios)) says the allocation is successful. I've tried to simplify the code and have attached a little example problem which seems to reproduce the issue. The problem arises when compiling with OpenMP active. Building the program with OpenMP OFF yields a successful run; turning it ON causes an ALLOCATE to fail without setting the STAT variable. A successful run should say:
> driver.exe
ONAME allocation succeeded
Output should be "a" on a line and "b" on the next line
a
b
The failed run shows:
> driver_omp.exe
Hmm. ONAME wasn't allocated???
Furthermore, the routine with the OpenMP commands is not even being invoked.
Interestingly, I get the same result both on windows with 14.0.0.103 Build 20130728 and on linux with 14.0.0.080 Build 20130728. The example program works correctly both with and without OpenMP when compiled with 13.1.0.149 Build 20130118 (on windows).
Allen
Thanks, we'll take a look.
Hi: Were you able to reproduce my problem?
Allen
Yes, I could. We are still investigating.
OK. Thanks for the response.
Escalated as issue DPD200248411. Curiously, /Qopenmp_stubs doesn't trigger the problem.
It looks as if this got fixed in Update 2.
Yes. Update 2 is solves all our problems. Thanks!
