29649 Discussions
#5528 error when using kernel32 Win API Modules on Fortran Compiler 2021.1.1
ShinyaHattori
I got a #5528 error when using kernel32 CreateDirectory and CopyFile on Intel Fortran Compiler 2021.1.1(w_oneAPI_2021.1.1.191).
But it worked in the Intel Visual Fortran Compiler 17.0.1.143.
Is this a bad code? Or is it a fortran bug like this?(https://community.intel.com/t5/Intel-Fortran-Compiler/USE-ADVAPI32-functions-in-openAPI-compiler/m-p/1257761)
The error and code are below.
Error
error #5528: The REFERENCE attribute cannot be used with a passed length CHARACTER variable on this platform
Code
program HelloIFX
use kernel32
implicit none
character(len=256) :: path_folder = "test"
integer(BOOL) :: ret_logi
integer :: ret
ret_logi = CreateDirectory(trim(path_folder)//""C, NULL)
ret = CopyFile("test.txt"C, "test2.txt"C, FALSE)
end program HelloIFX
mecej4
As described in the thread that you mentioned, the IFX compiler does have a bug in this regard. Please use the IFORT compiler driver (the "classic" driver).
mecej4
The updated compiler (2021.1.2) compiles the test code with no error messages.
ShinyaHattori
Thank you for the update information.
I installed Intel Fortran Compiler(Beta) 2021.1.2[Intel(R) 64] , but it didn't work.
1>Compiling with Intel® Fortran Compiler (Beta) 2021.1.2 [Intel(R) 64]...
1>HelloIFX.f90
1>C:/~/HelloIFX/HelloIFX.f90(10): error #5528: The REFERENCE attribute cannot be used with a passed length CHARACTER variable on this platform
mecej4
ShinyaHattori
OK. I'll use IFORT compiler driver (the "classic" driver) and I look forward to fixing the bug.
Steve_Lionel
You should continue using ifort for general use. By all means, if you want to, give ifx a try and report any issues, but understand that ifx is not claimed to be ready for production use.
