29641 Discussions
A BUG with allocatable component in type
Wei_J_3
Module ParticleOneModule
     Implicit none
     Type :: ParticleOne
          Real(8) ::  Vx,Vy,Vz
          contains
          procedure :: POPInit=>ParticleOnePositionInitialization
          procedure :: POVInit=>ParticleOneVelocityInitialization
          procedure :: POAInit=>ParticleOneAccelerationInitialization
          procedure :: POWInit=>ParticleOneWeightInitialization
      End Type ParticleOne
      Type,extends(ParticleOne) :: ParticleOne1D
          Real(8) ::  X
          contains
      End Type ParticleOne1D
       Type,extends(ParticleOne) :: ParticleOne2D
          Real(8) ::  X,Y
          contains
       End Type ParticleOne2D
       Type,extends(ParticleOne) :: ParticleOne3D
          Real(8) ::  X,Y,Z
          contains
       End Type ParticleOne3D
       Type,extends(ParticleOne) :: ParticleOne1DDI
          Real(8) ::  X,Ax
      End Type ParticleOne1DDI
       Type,extends(ParticleOne) :: ParticleOne2DDI
          Real(8) ::  X,Y,Ax,Ay
       End Type ParticleOne2DDI
       Type,extends(ParticleOne) :: ParticleOne3DDI
          Real(8) ::  X,Y,Z,Ax,Ay,Az
       End Type ParticleOne3DDI
        Type,extends(ParticleOne) :: ParticleOne1DC
            Real(8) ::  R,X,Y,W
        End Type ParticleOne1DC
         Type,extends(ParticleOne) :: ParticleOne2DC
            Real(8) ::  Z,R,X,Y,W
        End Type ParticleOne2DC
    contains
            subroutine ParticleOnePositionInitialization(PO,X,Y,Z)
		       Class(ParticleOne), intent(inout) :: PO
               Real(8),intent(in),optional :: X,Y,Z
               Real(8) :: Theta,R,PI=3.1415926d0
               Select Type(PO)
                   Type Is(ParticleOne1D)
                     PO%X=X
                   Type Is(ParticleOne2D)
                     PO%X=X
                     PO%Y=Y
                   Type Is(ParticleOne3D)
                      PO%X=X
                      PO%Y=Y
                      PO%Z=Z
                  Type Is(ParticleOne1DDI)
                     PO%X=X
                   Type Is(ParticleOne2DDI)
                     PO%X=X
                     PO%Y=Y
                   Type Is(ParticleOne3DDI)
                      PO%X=X
                      PO%Y=Y
                      PO%Z=Z
                   Type Is(ParticleOne1DC)
                       PO%R=X
                       Call RANDOM_NUMBER(R)
                       Theta=2.d0*PI*R
                       PO%X=Y*DCos(Theta)
                       PO%Y=Y*DSIn(Theta)
                   Type Is(ParticleOne2DC)
                       PO%Z=X
                       PO%R=Y
                      Theta=2.d0*PI*R
                      PO%X=Y*DCos(Theta)
                      PO%Y=Y*DSIn(Theta)
                END Select
            end subroutine ParticleOnePositionInitialization
            subroutine ParticleOneVelocityInitialization(PO,Vx,Vy,Vz)
            Real(8),intent(in),optional :: Vx,Vy,Vz
               PO%Vx=Vx
               PO%Vy=Vy
               PO%Vz=Vz
            end subroutine ParticleOneVelocityInitialization
           subroutine ParticleOneAccelerationInitialization(PO,Ax,Ay,Az)
                Real(8),intent(in),optional :: Ax,Ay,Az
                Select Type(PO)
                     PO%Ax=Ax
                     PO%Ax=Ax
                     PO%Ay=Ay
                       PO%Ax=Ax
                       PO%Ay=Ay
                      PO%Az=Az
                END Select
           end subroutine ParticleOneAccelerationInitialization
           subroutine ParticleOneWeightInitialization(PO,W)
                Real(8),intent(in) :: W
                Select Type(PO)
                       PO%W=W
                       PO%W=W
                END Select
           end subroutine ParticleOneWeightInitialization
END Module ParticleOneModule
Module ParticleBundleModule
      Use ParticleOneModule
     Implicit none
     Type :: ParticleBundle
           Integer(4) :: NPar=0,NParNormal=1000
           Real(8) :: Charge,Mass,Weight
           Real(8) :: XFactor,VFactor
           Real(8) :: Dx,Dt
           Class(ParticleOne),Allocatable :: PO(:)
           contains
      End Type ParticleBundle
    contains
            subroutine ParticleBundlePositionInitialization(PB)
		       Type(ParticleBundle), intent(inout) :: PB
               Real(8) :: X=1.d0,Y=2.0,Z=3.0
               Integer(4) :: i,NPar=10
               Do i=1,NPAR
                     Call PB%PO(i)%POPInit(X,Y)
               ENd DO
            end subroutine ParticleBundlePositionInitialization
END Module ParticleBundleModule
Program PIC_MCC_for_CCP
   Use ParticleBundleModule
   Implicit none
   TYPE(ParticleBundle) :: PBGlobal
   TYPE(ParticleOne2D) :: PBS(20)
   !Allocate(PBGlobal%PO,source=PBS)
   Allocate(ParticleOne1D::PBGlobal%PO(10))
   Call ParticleBundlePositionInitialization(PBGlobal)
   stop
end  Program
I want to try some OOP features, so I want to have a Type, in which the type of some component will be dynamically allocated.I assumed with Class in the type particle bundle, PBGlobal%OS will be allocated as ParticleOne1D, but in two cases with source or type defined in the allocate, it still only allocate a array of ParticleOne. I think it is a bug of the compiler. Any one can helpl me with that problem? Thanks!
I am not seeing incorrect behavior when this program is compiled with version 17.0.1. When ParticleOneInitializationPosition is called for each element of component PO, the SELECT TYPE correctly chooses the ParticleOne1D case. What are you seeing instead and which compiler version are you using?
Perhaps it would help if you instrumented the code with PRINT statements that show the path it's taking.
Wei_J_3
Dear Steve
Thanks a lot for the help and quick reply, I just found that that the debug can not show the PO%X and PO%Y correctly, but PO%X and PO%Y have been correctly allocated and valued. It is not a compiler bug. Thanks a lot!
