29488 Discussions
A deferred binding is inherited by non-abstract type; It must be overridden
gianluca__montenegro
I am trying to use deferred type bound procedures, which I gess are supported in the latest ifc 11.1.059 release, however I get the following error when I try to compile my code:
error #8313: A deferred binding is inherited by non-abstract type; It must be overridden [CP]
procedure(calculate_cp), deferred :: cp
I don't know where I made the mistake, any help?
Please find below the code.
Module var_specie_gm
IMPLICIT NONE
type, abstract :: polynomial
integer :: n_coeffs
real(8) :: upperTlimit
real(8) :: lowerTlimit
real(8) :: middleTlimit
contains
end type polynomial
type, extends(polynomial) :: janafThermo
real(8), dimension(5) :: a_ht
real(8), dimension(5) :: a_lt
real(8) :: b_ht
real(8) :: b_lt
real(8) :: c_ht
real(8) :: c_lt
contains
procedure :: cp => janaf_cp_from_temperature
end type janafThermo
abstract interface
function calculate_cp(poly,T) result(cp)
import :: polynomial
class(polynomial) :: poly
real(8), intent(IN) :: T
real(8) :: cp
end function calculate_cp
end interface
contains
function janaf_cp_from_temperature(poly,T) result(cp)
class(janafThermo) :: poly
real(8), intent(in) :: T
real(8) :: cp
if(:)then
endif
end function janaf_cp_from_temperature
end module var_specie_gm
Thank you in advance.
This is a compiler bug which I think is fixed in the upcoming Update 5. I'll check that and update this post.
Edit: I can't reproduce the problem with your excerpt, but a problem very much like this is indeed fixed in Update 5.
