A openMP question
FortCpp
Dear IVF users and developers,
I am learning OpenMP today. I followed a tutorial: http://www.openmp.org/presentations/miguel/F95_OpenMPv1_v2.pdf
But when I compile and run this:
[fortran]
    program OpenMPpractice
    implicit none
    ! Variables
    ! Body of OpenMPpractice
    !$OMP PARALLEL
        write(*,*) "Hello"
        !$OMP PARALLEL
            write(*,*) "Hi"
        !$OMP END PARALLEL
    !$OMP END PARALLEL
    end program OpenMPpractice
[/fortran]
The result is:
 Hello
 Hello
 Hello
 Hello
 Hi
 Hello
 Hello
 Hello
 Hi
 Hi
 Hello
 Hi
 Hi
 Hi
 Hi
 Hi
But according to the tutorial, I can see that there are 8 threads in the first level of parallel. But in the second level of parallel, the situation is different. I was thinking there should be 64 "Hi"s printed, but there are only 8.
Can anyone tell me what happened there?
Roman1
I think you need nested parallelism enabled.  Can you try adding:
call omp_set_nested(.true.)
Roman
FortCpp
Hi Roman,
It works! Thanks.
I add use omp_lib. Everything compiles OK.
