29339 Discussions
A problem with CLASS(*), POINTER and ASSOCIATE
FortranFan
Using compiler 15, update 3, I would expect the following simple code should generate a compiler error with the use of an associate-name x without select-type construct; note x is associated with an unlimited polymorphic pointer.  Instead, no compiler errors and warnings are generated.  At run-time, no exception occurs but nothing is printed for x for the statement on line 10.
program p
   implicit none
   class(*), pointer :: ptr
   allocate( ptr, source=1 )
   asc: associate ( x => ptr )
      print *, " x = ", x
   end associate asc
   deallocate(ptr)
   stop
end program p
Right you are. Since the selector is polymorphic, the associate-name is also. (But the associate-name, X, isn't a pointer - it does have TARGET.) As X is polymorphic, one must reference it within a SELECT TYPE construct.
Escalated as issue DPD200370511.
And with this, I'm officially on vacation. My colleagues will, I hope, take good care of you. See you in a couple of weeks.
FortranFan
Thanks, Steve.  Have a wonderful and safe vacation!
I expect this to be fixed in Update 2 (probably early February).
