29386 Discussions
A program can be compiled successfully, but not under gfortran??
changks888
Hi -
I am working on model comparison across various platform and computering environment.
A program can be compiled successfully using ifort, however I got some errors when I use gofrtran to compile it. (It can be compiled using gfortran in the Linux, but I am trying to compile it on a Mac.)
Below shows the errors:
gfortran main.o climate.o weather.o vegetation.o biogeochem.o initial.o humidity.o \\
radiation.o readpars.o canopy.o physiology.o snow.o soil.o utilities.o \\
ctemfire.o disturbance.o diagnostics.o io-cfs.o ies-io.o math.o stats.o nag-soil.o \\
-ffixed-line-length-132 -I/usr/local/include -L/usr/local/lib -lnetcdff -o ibis
Undefined symbols for architecture x86_64:
"_time_", referenced from:
_MAIN__ in main.o
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
make: *** [ibis] Error 1
bash-3.2$
I really appreciate your solutions and suggestions. Please help me.
Michael
The error you show is from linking, not compiling. It looks as if you are referencing a function named TIME which is not provided. TIME is provided as a generic intrinsic subroutine by Intel Fortran, but it is an extension, perhaps one that gfortran does not support. If portability is a goal, use the DATE_AND_TIME standard intrinsic instead. Read about it in the documentation.
changks888
Good hint! The original time function was dtime in gfortran. Thanks Steve!!!
TimP
dtime() and etime() were legacy precursors to the f95 intrinsic cpu_time, which could be used to replace them.
