29376 Discussions
A very serious bug introduced in the last update of CVF 6.6
jeanvezina
To all:
The last update of CVF 6.6, the C3 update, has introduced a
very serious bug. This was discussed recently in the
comp.lang.fortran newsgroup. I bring it to your attention here.
The bug is that array strides ARE NO LONGER FUNCTIONAL when an allocatable array is used.
Here is a test program
Code:
program test
implicit none
real, allocatable :: x(:)
allocate (x(10))
x = 1.0
print *,x(::2)
print *, size(x(::2))
end program test
If you compile and run this test program with the latest
update of CVF ( 6.6-4088-47D3B), you will see that
10 values are printed (instead of 5) and that the size
of the array section returned by the SIZE function is 10!
This bug was absent in the two previous C1 and C2 updates.
In my opinion, HP should fix this.
In our case, switching to the Intel 8.1 compiler is not an option
because it is stillunable (hang) to compile the large files produced by the Module Wizard .
Jean Vezina
I find it curious that it has taken eight months for this problem to be noticed. I don't recall seeing it reported to HP before this. In any event, I don't think anyone from HP reads this forum - please report it, if you haven't already, to vf-support@hp.com.
The long compile problem is being worked on.
jeanvezina
Jean Vezina
jeanvezina
Well, the vf-support@hp.com e-mail address appears to bedisabled as
my report bounced three times with the message:
host mail.compaq.com[161.114.64.101] said: 554
: Recipient address rejected: Access denied (in reply to RCPT TO command)
Jean Vezina
anthonyrichards
New Contributor III
The solution would appear to be to go back one update. How is that done, Steve?
Intel_C_Intel
I cut and pasted the code into a test workspace, but was unable to reproduce the error.
Win2K SP2, CVF 6.6C on a P4.
Both the default Debug and Release Builds produce five vales printed and a size of 5.
The Help>About for MSVS does not give the full designation you mention for the 6.6C update (6.6-4088-47D3B). How can I confirm that I am [not] testing the same subversion of the compiler?
Cliff
jeanvezina
Open a DOS box (command prompt), and type:
df /what
The exact compiler version will be displayed.
Jean Vezina
Try vf-support@compaq.com if the hp.com address doesn't work. It should.
The C3 update will show, in df-what:
Compaq Visual Fortran 6.6-4088-47D3B
I don't know if the earlier 6.6C updates are on the FTP site - possibly not. They both had VERY serious bugs. I suspect that this particular bug is less serious than it seems at first and may depend on some other particular aspect of the program being used.
If you need to back up, you have to uninstall CVF, reinstall 6.6 and then apply the update you want.
lklawrie1
I couldn't make it work as stated in CVF 6.6C but I moved the size above the first print and, yes, it prints out 10, etc as stated.
I can verify the program segment works as the user expects in IVF 8.1 as well as Lahey 7.1.1
Linda
gregscvf
FWIW,
Using C3, I repeat the errorof 10 with the "Print *, size..." statement, but the "Print *, x(::2)"statement gives: Array bound exceeded.
But both commands work fine using x(:10:2), or x(1:10:2).
Greg
jeanvezina
To all:
The HP support e-mail address now works and I was able to send a problem report. It was assigned the problemnumber CVF22412.
The fact that the test program behaves differently from user to user
seems to show that the generated coderefersto unitialized memory
locations for the array descriptor.
Jean Vezina
Intel_C_Intel
Jean,
C:>df /what
Compaq Visual Fortran 6.6-3780-47D3B
This subversion doesn't seem to have the stride problem. You could revert to that subversion, but earlier comments in this thread make it sound like it has other bugs I haven't run into yet.
Good Luck, Cliff
Jugoslav_Dujic
Valued Contributor II
As I recall, the problems with two earlier versions were mostly related with F9x standards checking (that I don't care about). I happily use the same 3780 version (the first 6.6C release?) for more than a year. But then, I don't care about this stride problem in 4088 either :-).
Jugoslav
anthonyrichards
New Contributor III
DF /what on my installationgives
C:Program FilesMicrosoft Visual StudioDF98BIN>df /what
Compaq Visual Fortran Optimizing Compiler Version 6.6 (Update C
Copyright 2003 Compaq Computer Corp. All rights reserved.
Compaq Visual Fortran 6.6-4018-47D3B
C:Program FilesMicrosoft Visual StudioDF98BINdecfor90.exe
Am I ok? Or is the original poster misprinting 4018 as 4088 ?
Jugoslav_Dujic
In short:
1st version:
CVF-66-66C.exe (Nov 2003)
2ndversion:
CVF-66-6C.exe (Jan 2004)
3rfversion:
CVF-66-66C3.exe (Feb 2004)
Jugoslav
anthonyrichards
New Contributor III
Thanks, Jugoslav.
