AMD Athlone 64 compatibility
bbradley
Is the latest version (9.1.025) completely compatible with AMD chips ?
TimP
Option -QxK is compatible with Athlon-32
-QxW with Athlon-64 and Opteron
Intel_C_Intel
Ah, I should have been more specific. A console application compiled with Intel Fortran 9.1.025 runs with no problem on *real* Intel chip powered machines. With the exact same program and input data, it fails on an AMD Athlon 64 powered system, running Windows XP.
The first trial was with the program compiled in Debug mode, so no optimizations were used. The second trial was a Release version, optimized for speed, but no specific Intel optimizations. Both test failed at exactly the same line number.
TimP
This looks like a case which you should submit as a problem report on premier.intel.com.
