ASSIGN VECTOR INSIDE MODULE
Luis_Thiago_L_
Hello eveybody,
I would like to know how can i assign vector values inside a module.
For Example:
    MODULE BDCOMB
! COMMON BLOCK BDCOMB CONTAINS RANDOM BAND PARAMETERS FOR THE LW CALCULATIONS USING COMBINED WIDE
! FREQUENCY BANDS BETWEEN 160 AND 1200 CM-1,AS WELL AS THE 2270-2380 BAND FOR SOURCE CALC.
! BANDS 1-8:  COMBINED WIDE FREQUENCY BANDS FOR 160-560 CM-1
! BANDS 9-14: FREQUENCY BANDS,AS IN BANDTA (NARROW BANDS) FOR 560-1200 CM-1
! BAND  15:   FREQUENCY BAND 2270-2380 CM-1,USED FOR SOURCE CALCULATION ONLY THUS NBLY PRESENTLY
!             EQUALS 15
! BANDS ARE ARRANGED IN ORDER OF INCREASING WAVENUMBER
! ACOMB       = RANDOM "A" PARAMETER FOR (NBLY) BANDS
! BCOMB       = RANDOM "B" PARAMETER FOR (NBLY) BANDS
! BETACM      = CONTINUUM COEFFICIENTS FOR (NBLY) BANDS
! APCM,BPCM   = CAPPHI COEFFICIENTS FOR (NBLY) BANDS
! ATPCM,BTPCM = CAPPSI COEFFICIENTS FOR (NBLY) BANDS
! BDLOCM      = LOWEST FREQUENCY IN EACH OF (NBLY) FREQ. BANDS
! BDHICM      = HIGHEST FREQUENCY IN EACH OF (NBLY) FREQ. BANDS
! AO3CM       = RANDOM "A" PARAMETER FOR OZONE IN (3) OZONE BANDS
! BO3CM       = RANDOM "B" PARAMETER FOR OZONE IN (3) OZONE BANDS
! AB15CM      = THE PRODUCT ARNDM*BRNDM FOR THE TWO BANDS REPRESENTING THE 15 UM BAND COMPLEX
!               OF CO2
! BETINC      = CONT.COEFFICIENT FOR A SPECIFIED WIDE FREQ.BAND (800-990 AND 1070-1200 CM-1).
! IBAND       = INDEX NO OF THE 40 WIDE BANDS USED IN COMBINED WIDE BAND CALCULATIONS. IN OTHER
!               WORDS, INDEX TELLING
! WHICH OF THE 40 WIDE BANDS BETWEEN 160-560 CM-1 ARE INCLUDED IN EACH OF THE FIRST 8 COMBINED
! WIDE BANDS
! DATA FOR ACOMB, BCOMB, APCM, BPCM, ATPCM, BTPCM, AO3CM, BO3CM ARE OBTAINED BY USING THE AFGL
! 1982 CATALOG.
! CONTINUUM COEFFICIENTS ARE FROM ROBERTS (1976).
! IBAND INDEX VALUES ARE OBTAINED BY EXPERIMENTATION.
! CALLED: RDPARM
! DRIVER: RNDDTA
    USE RDPARM, ONLY : NBLY
    INTEGER, PUBLIC, DIMENSION (40)   :: IBAND
    REAL,    PUBLIC, DIMENSION (NBLY) :: ACOMB, BCOMB, BETACM, APCM, BPCM, ATPCM, BTPCM, BDLOCM,  &
    &                                    BDHICM
    REAL,    PUBLIC, DIMENSION (2)    :: AB15CM
    REAL,    PUBLIC, DIMENSION (3)    :: AO3CM, BO3CM
    REAL,    PUBLIC                   :: BETINC
    DATA IBAND  /        &
    & 2, 1, 2, 2, 1, 2, 1, 3, 2, 2, 3, 2, 2, 4, 2, 4, 2, 3, 3, 2,                                 &
    & 4, 3, 4, 3, 7, 5, 6, 7, 6, 5, 7, 6, 7, 8, 6, 6, 8, 8, 8, 8 /
    DATA ACOMB  /        &
    &  0.152070E+05,  0.332194E+04,  0.527177E+03,  0.163124E+03,  0.268808E+03,  0.534591E+02,   &
    &  0.268071E+02,  0.123133E+02,  0.600199E+01,  0.640803E+00,  0.501549E-01,  0.167961E-01,   &
    &  0.178110E-01,  0.170166E+00,  0.537083E-02/
    DATA BCOMB  /        &
    &  0.152538E+00,  0.118677E+00,  0.103660E+00,  0.100119E+00,  0.127518E+00,  0.118409E+00,   &
    &  0.904061E-01,  0.642011E-01,  0.629660E-01,  0.643346E-01,  0.717082E-01,  0.629730E-01,   &
    &  0.875182E-01,  0.857907E-01,  0.214005E+00/
    DATA BETACM /        &
    &  0.000000E+00,  0.000000E+00,  0.000000E+00,  0.000000E+00,  0.188625E+03,  0.144293E+03,   &
    &  0.174098E+03,  0.909366E+02,  0.497489E+02,  0.221212E+02,  0.113124E+02,  0.754174E+01,   &
    &  0.589554E+01,  0.495227E+01,  0.000000E+00/
    DATA APCM   /        &
    & -0.671879E-03,  0.654345E-02,  0.143657E-01,  0.923593E-02,  0.117022E-01,  0.159596E-01,   &
    &  0.181600E-01,  0.145013E-01,  0.170062E-01,  0.233303E-01,  0.256735E-01,  0.274745E-01,   &
    &  0.279259E-01,  0.197002E-01,  0.349782E-01/
    DATA BPCM   /        &
    & -0.113520E-04, -0.323965E-04, -0.448417E-04, -0.230779E-04, -0.361981E-04, -0.145117E-04,   &
    &  0.198349E-04, -0.486529E-04, -0.550050E-04, -0.684057E-04, -0.447093E-04, -0.778390E-04,   &
    & -0.982953E-04, -0.772497E-04, -0.748263E-04/
    DATA ATPCM  /        &
    & -0.106346E-02,  0.641531E-02,  0.137362E-01,  0.922513E-02,  0.136162E-01,  0.169791E-01,   &
    &  0.206959E-01,  0.166223E-01,  0.171776E-01,  0.229724E-01,  0.275530E-01,  0.302731E-01,   &
    &  0.281662E-01,  0.199525E-01,  0.370962E-01/
    DATA BTPCM  /        &
    & -0.735731E-05, -0.294149E-04, -0.505592E-04, -0.280894E-04, -0.492972E-04, -0.341508E-04,   &
    & -0.362947E-04, -0.250487E-04, -0.521369E-04, -0.746260E-04, -0.744124E-04, -0.881905E-04,   &
    & -0.933645E-04, -0.664045E-04, -0.115290E-03/
    END MODULE BDCOMB
Thank you very much for your attention.
All the best
jimdempseyatthecove
Are DATA initial items for variables (subject to change during runtime).
.OR. are they fixed parameters?
Jim Dempsey
Steve_Lionel
Would you please explain in more words what you are trying to do? I am not certain I know what you mean by "assign vector". What did you try that didn't work? What effect do you want? Your module is just declarations and has no executable part.
Luis_Thiago_L_
Thank for Reply,
Some DATA's are the initial values, others are fixed parameters.
I Just want to start my MODULES with this DATA values inside them, for example:
IBAND(1) = 2
IBAND(2) = 1
IBAND(3) = 2
IBAND(4) = 2
I Just tried :
INTEGER, PARAMETER, PUBLIC, DIMENSION(40)  :: IBAND = [  2, 1, 2, 2, 1, 2, 1, 3, 2, 2, 3, 2, 2, 4, 2, 4, 2, 3, 3, 2, 4, 3, 4, 3, 7, 5, 6, 7, 6, 5, 7, 6, 7, 8, 6, 6, 8, 8, 8, 8 ]
But when i do
USE BDCOMB
the values Assigned to IBAND do not come.
Steve_Lionel
That should have worked. Would you please attach a small but complete source that shows the problem? Note that if you use PARAMETER, these are "named constants" and not variables. If you don't ever change the value(s) of IBAND, this is fine.
