29533 Discussions
AVAILABLE NOW! Intel HPC Toolkit 2024.1
Devorah_H_Intel
New in Intel® HPC Toolkit
  • Intel® Fortran Compiler adds more Fortran 23 language features - improving compatibility and interoperability between C and Fortran code in the intrinsic module ISO_C_BINDING; simplifying trigonometric calculations by allowing developers to use intrinsic functions that accept arguments as degrees, enhancing ease of use and code readability; use of predefined data types of specific sizes in intrinsic module ISO_FORTRAN_ENV improving code portability and ensuring consistent behavior, and more.
  • Intel® Fortran Compiler makes OpenMP Offload programming more productive by adding runtimes checks ensuring that mapped data is currently allocated/associated.
  • Developers can achieve higher application performance using GPU Remote Memory Access (RMA) for more efficient access to remote memory via one-sided communication in the Intel® MPI Library.
  • Developers can now achieve higher performance and productivity using the new MPI 4.0 Persistent Collectives feature.
  • Developers can now enjoy higher productivity through reduced code changes when implementing large-count operations by using the new MPI 4.0 Large Counts feature.
Download the toolkit here.
