About integer KIND parameter
Blane_J_
I was doing some tests on integer kind type parameters and something went wrong like: when I assign the value Z'80000000' to INTEGER(KIND=4) variable, the compiler generates a warning message saying that "The INTEGER(KIND=4) value is out-of-range"; But there's nothing odd when I assign Z'80' to INTEGER(KIND=1) variable as well as assign Z'8000' to INTEGER(KIND=2). So is it a compiler bug or something? By the way, Intel Parallel Studio 2015 is my current compiler.
mecej4
In an assignment statement v = e, the kind of the variable v need not be the same as the kind of the expression e. Try this very short program:
write(*,*)kind(Z'80'),kind(Z'8000'),kind(Z'80000000')
end
If you want to change the kind of the expression e to something other than the default kind for the type, the language gives you the means to do so.
Blane_J_
Thank you, mecej4. I've tried your program and it all returned value 4. Does that mean the  kind type of parameters like Z'xxxxxxxx'  are acquiescently INTEGER(KIND=4)?
It is not standard Fortran to use the Z'nnnn' syntax in this context. See Binary, Octal, Hexadecimal, and Hollerith Constants and especially the subsection Determining the Data Type of Nondecimal Constants. (Note - the documentation link will probably become broken in a future release - see the FAQ for the current starting link for documentation.)
Blane_J_
Thank you so much, Steve. I've read the pages you mentioned and I got a clear view on this issue now.
