About "if ... then"
brb36641
Would someone give me instruction about method of "if ... then"?
I wonderwhich codewould be done whenty value will be changed from false to true as follows.
ty = .false.
ty = .true
if (ty) then
write ("true")
else
write("false")
end if
I really want to know which word, true/false, would be out into file.
Please someone help me as soon as possible.
Les_Neilson
Valued Contributor II
I assume the actual code is not what you have written in your original post.
if (ty) then
else
means "if ty is .TRUE. then execute the following statements up to the else."
so ifin the code before the else, you are writing a value "true" to a file then that is the value you should see in the file.
If ty is *not* true then the statements between the else and the endif will be executed.
If you are still having problems then I suggest you post the actual code with a description of the problem.
Les
hansr
The code above writes "false", because there is no finalize dot in the line ty = ".true" and ty remains ".false." Hans
brb36641
Thank you very much for instructions.
Both instructioins are so helpful for beginer like me.
The code in the original post contains several syntax errors so would not compile (the missing dot is just one of them.) I assume that the actual code looks somewhat different and therefore it's very difficult to know what the actual problem is.
