29652 Discussions
Access Violation in Character Array Allocation
Allen_Barnett
I'm having trouble with FoX, an XML parsing library written in FORTRAN. See http://www1.gly.bris.ac.uk/~walker/FoX/. When FoX reads a file, it collects characters one at a time by repeatedly allocating and copying between a pair of CHARACTER(:) pointers. When this array exceeds 998 characters, IVF appears to give an access violation. I reduced the problemmatic code in FoX to the shortish example shown below. I'm using IVF 11.1.067.
Allen
[bash]module fox_m_fsys_array_str
  implicit none
  private
  interface destroy
    module procedure destroy_vs
  end interface
  interface alloc
    module procedure vs_str_alloc
  end interface
  public :: str_vs
  public :: vs_str
  public :: vs_str_alloc
  public :: vs_vs_alloc
  public :: alloc
  public :: destroy
contains
  pure function str_vs(vs) result(s)
    character, dimension(:), intent(in) :: vs
    character(len=size(vs)) :: s
    s = transfer(vs, s)
  end function str_vs
  pure function vs_str(s) result(vs)
    character(len=*), intent(in) :: s
    character, dimension(len(s)) :: vs
    vs = transfer(s, vs)
  end function vs_str
  pure function vs_str_alloc(s) result(vs)
    character, dimension(:), pointer :: vs
    allocate(vs(len(s)))
    vs = vs_str(s)
  end function vs_str_alloc
  pure function vs_vs_alloc(s) result(vs)
    character, dimension(:), pointer :: s
    if (associated(s)) then
      allocate(vs(size(s)))
      vs = s
    else
      vs => null()
    endif
  end function vs_vs_alloc
  subroutine destroy_vs(vs)
    deallocate(vs)
  end subroutine destroy_vs
end module fox_m_fsys_array_str
program main
  use fox_m_fsys_array_str, only: str_vs, vs_str_alloc
  character, pointer :: tempString1(:) => null()
  character, pointer :: tempString2(:) => null()
  tempString2 => vs_str_alloc( "" )
  ! Works
  do i = 1, 998
     tempString1 => tempString2
     tempString2 => vs_str_alloc( str_vs( tempString1 ) // ' ' )
     deallocate( tempString1 )
  end do
  print *, size(tempString2), "'", tempString2, "'"
  deallocate( tempString2 )
  ! Fails
  do i = 1, 999
  end do
  read (*,*)
end program
[/bash]
It's getting a stack overflow. If you increase the stack reserve size, it passes.
I suspect what is happening is that the function result of the call to vs_str_alloc (the pointer) doesn't get taken off the stack after the pointer assignment completes. We'll take a look at that. Issue ID is DPD200161472.
Allen_Barnett
I see that FORTRAN Composer XE 2011 update 1 was released. Should I be looking for DPD200161472 in this list http://software.intel.com/en-us/articles/intel-composer-xe-2011-compilers-fixes-list/ ?
Yes, that's what you would look for.
This was fixed in Composer XE 2011 Update 6.
