Access version resource from code
Brian_Triplett
I'm trying to access version information about my fortran program in code (for output printing and so forth). Presently that information is stored in a resource file (Version.rc) in my Visual Studio project file (*.vfproj).
Is it possible to access the information in the resource file from code? If so, are there any example of doing this?
netphilou31
New Contributor III
Please find enclosed a piece of code I use for retrieving the version number of a dll. I guess that you can adapt it to your needs.
[fxfortran]      subroutine GetVersionInfoString(EXE_Name, VERSION_INFO)
      use DFWIN
      implicit none
C
      character(len=*), intent(in) ::  EXE_Name
      character(len=*), intent(out) :: VERSION_INFO
C
C     Reading the version number of an executable (or dll)
C
      integer(4)         Hndl
      integer(4)         nBytes
      integer(4)         rc
      character(len=256) StringInfo
      character(len=8)   CharSet
C
      integer(4)         uVersionLen, uTranslationLen
      integer(4)         lpstrVffInfo, lpstrVffInfo1
      integer(4)         hMem
      integer(4)         i
      character(len=256) lpversion
      integer(1)         lpTranslation(256)
      integer(4)         pTranslation
C
      nBytes = GetFileVersionInfoSize(EXE_Name, LOC(Hndl))
C
      if (nBytes /= 0) then
          hMem = GlobalAlloc(GMEM_MOVEABLE, int(nBytes))
          lpstrVffInfo = GlobalLock(hMem)
          rc = GetFileVersionInfo(EXE_Name, Hndl, nBytes, lpstrVffInfo)
          StringInfo = "\VarFileInfo\Translation"C
          rc = VersionQueryValue(lpstrVffInfo, loc(StringInfo), loc(lpTranslation), loc(uTranslationLen))
          write(CharSet,'(4z2.2)') lpTranslation(2),lpTranslation(1),lpTranslation(4),lpTranslation(3)
          StringInfo = "\StringFileInfo\"//CharSet//"\FileVersion\"C
          rc = VersionQueryValue(lpstrVffInfo, loc(StringInfo), loc(lpVersion), loc(uVersionLen))
          if (rc /= 0) then
              rc = lstrcpy(VERSION_INFO, lpVersion)
              uVersionLen = min(uVersionLen,index(VERSION_INFO,char(0)))
              do i=uVersionLen,LEN(VERSION_INFO)
                 VERSION_INFO(i:i) = ' '
              end do
          else
              VERSION_INFO = 'n.c'
	  end if
          rc = GlobalUnlock(hMem)
          rc = GlobalFree(hMem)
      else
      end if
C
      return
      end
[/fxfortran]
Yes. First you call GetModuleHandle with a NULL argument to get a handle to the running EXE. Then you call GetFileVersionInfoEx to retrieve the version information. See the MSDN documentation on these routines for details. One of the things you have to do is get the "size" of the version info first, allocate a block of the desired size, and then get the actual data. I have done this in Fortran but don't think I have the code I used handy.
netphilou31
New Contributor III
      use DFWIN
      implicit none
C
C
C
      integer(4)         Hndl
      integer(4)         nBytes
      integer(4)         rc
C
      integer(4)         hMem
      integer(4)         i
C
C
          if (rc /= 0) then
              end do
          else
	  end if
      else
      end if
C
      return
      end
[/fxfortran]
bmchenry
New Contributor II
been messsing with this code and ran into a couple of things:
1) This uses DFWIN. Also works with IFWIN. Is there anydifference between DFWIN v IFWIN?
2) VersionInfoQuery now VerInfoQuery, changing doesn't seem to make any difference
3) on line rc = VerQueryValue(lpstrVffInfo, loc(StringInfo), loc(lpVersion), loc(uVersionLen))
it always returns 0
Anyone look at code and see a problem/issue?
Thanks!
b
netphilou31
New Contributor III
I developed this portion of code with CVF (COMPAQ Visual Fortran). At that time the module name was DFWIN, but now with Intel Visual Fortran, it has been renamed IFWIN, although a compatibility module is still available. For the other issues I did not test the code using IVF.
bmchenry
New Contributor II
aha! therein lies the issue!
i thought it was something that worked on IVF.
OK, that gives me a clue why it wasn't working as expected!
also foundat
http://software.intel.com/en-us/forums/showthread.php?t=78525&o=a&s=lr
from Steve:
The handles (hMem, etc.) should be declared INTEGER(HANDLE). The "lp" variables should be INTEGER(LPVOID).
Guess i'll try that!
thanks!
Michiel_Tukker
Sorry to kick the topic, but I encountered the same issue where the above code wouldn't work. After some tinkering and combining several posts on the internet, I got it working. Here's my code (works in IVF 11)
#define MAX_PATH 260+1
subroutine GetVersionInfoStrings(FILEVERSION)
	use IFWIN
	implicit none
	character(len=*), intent(out) :: FILEVERSION
	integer(4)         Hndl
	integer(4)         nBytes
	integer(4)         rc
	character(100)     lpVersion
	integer(4)         hMem
	integer(4)         i
	character(MAX_PATH) szFilename
	pointer(lplpVersion, lpversion)
	rc = GetModuleFileName(NULL, szFilename, MAX_PATH)
	nBytes = GetFileVersionInfoSize(szFilename, LOC(Hndl))
		rc = GetFileVersionInfo(szFilename, Hndl, nBytes, lpstrVffInfo )
		StringInfo = "\\StringFileInfo\\040904b0\\FileVersion"C  !hex 040904b0 is the code page set in the resource file
		rc = VerQueryValue(lpstrVffInfo, loc(StringInfo), lplpVersion, loc(uVersionLen))
		if (rc /= 0) then
			rc = lstrcpy(FILEVERSION, lpVersion)
			uVersionLen = min(uVersionLen,index(FILEVERSION,char(0)))
			do i=uVersionLen,len(FILEVERSION)
				FILEVERSION(i:i) = ' '
			end do
		else
			FILEVERSION = 'n.c'
		end if
	else
		FILEVERSION = 'n.c'
	end if
end
Your code won't work in a 64-bit application. See bmchenry's post above yours.
