29382 Discussions
Access violation: Trying to use Class(*)
abhimodak
The snippet below compiles fine but gives an access violation error at line # 45. The debugger does show the "Object" components correctly.
Abhi
Module myTest
Implicit None
Contains
Subroutine Test(Object, i, Method)
Implicit None
Class(*) :: Object
Integer :: i
External :: Method
Call Method(Object, i)
End Subroutine Test
End Module myTest
Module myType
Implicit None
Type newObject
Integer :: i = 1
Real :: r = 0.0
Contains
Procedure :: ShowMe
End Type newObject
Contains
Subroutine ShowMe(Object, i)
Implicit None
Class(newObject) :: Object
Integer :: i
Print *, i
Print *, Object%i
End Subroutine ShowMe
End Module myType
Program Test_Class
Use myType
Use myTest
Implicit None
Type(newObject) :: Object
Call Test(Object, Object%i, ShowMe)
End Program Test_Class
reinhold-bader
New Contributor II
Some remarks about Steve's version of the code:
Error 1 can in this case very simply be avoided by not making showme a type-bound procedure of newobject (one is not obliged to do so, and there are some (other) situations where it is in fact not possible).
Error 2 however I consider to be spurious, since a CLASS(*) dummy should match an actual of any type. To confirm this I also tried NAG's compiler, which had no difficulties with the "no-TBP" version of the code.
Reinhold
"Method" needs an explicit interface because the called routine has a polymorphic argument. EXTERNAL is not sufficient. I will admit that I don't yet have my head wrapped around all this OO stuff, and I'm having difficulty modifying your code to be valid. I've gotten this far:
[plain]Module myTest
Implicit None
Contains
Implicit None
Class(*) :: Object
Integer :: i
interface
subroutine Method (Object, i)
import
class(*) :: Object
integer :: i
end subroutine Method
end interface
End Subroutine Test
End Module myTest
Module myType
Implicit None
Type newObject
Integer :: i = 1
Real :: r = 0.0
Contains
Procedure :: ShowMe
End Type newObject
Contains
Implicit None
Class(*) :: Object !???
Integer :: i
select type (Object)
type is (newObject)
Print *, i
Print *, Object%i
end select
End Module myType
Program Test_Class
Use myType
Use myTest
Implicit None
End Program Test_Class[/plain]
But the compiler complains:
(42) error #8262: The passed-object dummy argument must be dummy data object with the same declared type as the type being defined. [OBJECT]
(69) error #7061: The characteristics of dummy argument 1 of the associated actual procedure differ from the characteristics of dummy argument 1 of the dummy procedure. (12.2) [SHOWME]
abhimodak
Hi Steve
As I understand the error 1 is because the rule on the passed-object for the type-bound procedure and error 2 is because class(*) is not equal to another class(*). {However, I am unsure if the explicit interface is "required". If so, it should have given a compile-time error.}
What I am trying to do is to get Subroutine Test call Method(Object, i, r, ...). Subroutine Test itself has nothing to do with the "Object". The arguments i, r etc will be common to all object types.
In the snippet below I have used abstract type and thus can achieve what I was trying to do. Clearly, I cannot "free" the subroutine Test of knowing the abstract type (i.e. use Class(*)).
Abhi
Module Basic
Implicit None
Type, Abstract :: Parent
Contains
Procedure(Scheme), Deferred :: Method
End Type
Abstract Interface
Subroutine Scheme(Model, i)
Import
Class(Parent) :: Model
Integer :: i
End Subroutine Scheme
End Interface
End Module Basic
Module Derived
Use Basic
Type, Extends(Parent) :: Child
Integer :: m
Real :: r
Contains
Procedure :: Method
End Type
Contains
Subroutine Method(Model, i)
Implicit None
Class(Child) :: Model
Integer :: i
Print *, i
Print *, Model%m
End Subroutine Method
End Module Derived
Module myTest
Use Basic
Implicit None
Contains
Subroutine Test(Model, i)
Implicit None
Integer :: i
Call Model%Method(i)
End Subroutine Test
End Module myTest
Program Test_AbstractType
Use myTest
Use Derived
Implicit None
Type(Child) :: This
Integer :: n = 3
This%m = 1
This%r = 0.0
Call Test(This, n)
End Program Test_AbstractType
I agree that the compiler should not let you pass a class(*) object to a routine with an implicit interface. I'll pass that on.
reinhold-bader
New Contributor II
Reinhold
I agree - entered as bug DPD200139700.
The standard says that even though unlimited polymorphic CLASS(*) has "no declared type", it is type compatible with everything.
I've reported A. Do you have a test case for B? I don't see an "UNPOLY" anywhere.
abhimodak
Hi Steve
I get the error in with the snippet I posted. I am using IVF11.1.038 on WinXP64 with VS2005 professional. The "output" window has the following:-
1>------ Rebuild All started: Project: Test_Class, Configuration: Debug Win32 ------
1>Deleting intermediate files and output files for project 'Test_Class', configuration 'Debug|Win32'.
1>Compiling with Intel Visual Fortran 11.1.038 [IA-32]...
1>Test_Class.f90
1>C:AbhiMySourceTestsTest_ClassTest_Class.f90(69): error #6404: This name does not have a type, and must have an explicit type. [#UNLPOLY]
1>(72): catastrophic error: Internal Compiler Error: possible out of order or missing USE
1>compilation aborted for C:AbhiMySourceTestsTest_ClassTest_Class.f90 (code 1)
1>
1>Build log written to "file://C:AbhiMySourceTestsTest_ClassDebugBuildLog.htm"
1>Test_Class - 2 error(s), 0 warning(s)
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Oh, I get it now. Yes, I'll report that. Issue ID is DPD200139745.
This problem is corrected in 11.1 Update 3, available now.
