Accessible error in interface block
razi101
Dear all,
I'm trying to port f77 / f90 codes which run well with Compaq VF on Windows XP to our newly installed IFC version 7.1 on Redhat 9.0 smp cluster (aware of the library problem--now run with -i_dynamic in ifc.cfg).
I've got an IO error 119 when compiling a module in which interface
blocks are declared. The error consistently occurs in the blocks where a function is declared with real (DP) and the variables are also real (DP) like below
interface
real (DP) function area(x1,y1,x2,y2,x3,y3)
use somemodule
implicit none
real (DP) x1,y1,x2,y2,x3,y3 !----got the IO error on this line
intent (in) :: x1,y1,x2,y2,x3,y3
end function area
end interface
It seems that ifc is not happy with real (DP) being declared twice in a block? I always get "More than one program entity with this name is accessible" (Error 119)
Is there a work around to this problem? Not too sure if version 8.0 will solve this? Unfortunately we're not yet entitled to the Intel Premier Support.
By the way, is there a good documentation on migrating/exporting source codes from Compaq VF on windows to IFC on Linux? I've got a pretty useful article by Steve Lionel, but that's about it. I'm rather new in Fortran, and only recently have been tinkering with IFC.
Thanks!
Razi Abdul
razi101
Hi all,
OK, it works now with 8.0...
My second query remains open, though :)
Razi Abdul
Hamburg, Germany
I'm not aware of an article specifically addressing porting CVF to Intel Fortran on Linux. The release notes (and an article I am writing regarding porting CVF to Intel Fortran on Windows) do cover source differences, but I would not expect a lot of problems unless you make use of WIndows-only features.
If you have specific issues, feel free to ask about them here.
