29657 Discussions
Add IMSL libraries to a Visual Studio Project
Alessandro_D_
I have the IMSL libraries on my PC and I manage to run the program below in VS Code, using a makefile. However I don't manage to add the libraries when I use Visual studio (the integration).
Can someone explain me how I have to modify the project properties to add the IMSL libraries.
The attached figures show what I have done so far: go to properties>linker>general>additional library directories and then add the following three lines
C:\Program Files (x86)\RogueWave\imsl\fnl-2024.1.0\win100in240x64\include\dll
C:\Program Files (x86)\RogueWave\imsl\fnl-2024.1.0\win100in240x64\include\static
C:\Program Files (x86)\RogueWave\imsl\fnl-2024.1.0\win100in240x64\lib
but I get the following error:
Error in opening the compiled module file. Check INCLUDE paths [DENSE_LP_INT]
Cannot open include file 'link_fnl_static.h'
Thanks!
program test_solve_lin
USE DENSE_LP_INT, only: DENSE_LP
include 'link_fnl_static.h'
IMPLICIT NONE
INTEGER, PARAMETER :: M=4, NVAR=6
INTEGER :: i
REAL(8) :: OBJ
REAL(8) :: A(M, NVAR), B(M), C(NVAR), XSOL(NVAR), DSOL(M), BL(M), BU(M)
INTEGER :: IRTYPE(M)
! TODO: Modernize this old crap
DATA A/1, 1, 1, 0, 1, 1, 0, 1, 1, 0, 0, 0, 0, -1, &
0, 0, 0, 0, 1, 0, 0, 0, 0, 1/
DATA B/1.5, 0.5, 1.0, 1.0/
DATA C/-1.0, -3.0, 0.0, 0.0, 0.0, 0.0/
DATA BL/1.5, 0.5, 1.0, 1.0/
DATA BU/M*-1.D30/
!DATA IRTYPE/M*0/
IRTYPE(:) = 0
! Solve the LP problem
write(*,*) "-----------------------------------------"
write(*,*) "DENSE_LP, from IMSL Fortran Library"
CALL DENSE_LP(A, BL, BU, C, IRTYPE, OBJ, XSOL, DSOL)
write(*,*) 'Objective = ', OBJ
write(*,*) 'Solution = '
do i = 1, NVAR
write(*,'(X,I,X,F9.4)') i, XSOL(i)
enddo
end program test_solve_lin
Steve_Lionel
You'll need to take this up with the IMSL support people. However, I'll suggest that the paths that have "/include" should instead go in Fortran > General > Additional Include Directories, and that you really want only one of those depending on whether you want to link to the static or DLL form of the IMSL libraries.
Mike6723
Hi Alessandro,
Step by step instructions are provided in the section, "Using FNL with Visual Studio" within the IMSL FNL README file (https://help.imsl.com/fortran/common/README.html).
--Mike
