Add watch failed everytime
cean
New Contributor II
I am using Intel Fortran 2023.2. When I try to add a quickwatch, I get msg same as this: worker process failed.
https://community.intel.com/t5/Intel-Fortran-Compiler/quot-The-debugger-s-worker-process-msvsmon-exe-unexpectedly/m-p/1026350#M109366
This thread is old. Don't know if it suits my new version?
Cheers,
Cean
andrew_4619
seems broken I would suggest repair/reinstall.
jimdempseyatthecove
What version of Windows are you using?
What version of MSVS are you using?
I've never experienced this error before (since Windows XP and MS VS 2005, IVF V 8.0 and thru all upgrades).
can you send a screenshot of what you are entering into the quickwatch window?
Jim Dempsey
cean
New Contributor II
Win 10 pro 22H2
VS Version 17.7.5
I just add a break point, run to it. Then hoover over a variable before the point and right click to pick addwatch. It pops up a msgbox saying msvs is evluating the variable. after a while, the error msg pops up and msvs shut down.
andrew_4619
jimdempseyatthecove
I have MS VS 2022 Community version17.8.2. Prior to that MS VS Pro 2019. No problems.
I am aware that newer/newest release may have integration issues.
Your older version is not that old and should integrate OK.
Follow @andrew_4619 suggestion to repair/reinstall.
Jim Dempsey
