hi,
I have two function calls from my C# code to Fortran (DoSomething() and PROGRESS()). I can call the function DoSomething() with no issues, but when i tried to add another function call (i.e PROGRESS()), i get the following error message.
An unhandled exception of type 'System.TypeLoadException' occurred in Microsoft.VisualStudio.HostingProcess.Utilities.dll
Additional information: Could not load type 'FortMod' from assembly 'FortMod, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' because the method 'PROGRESS' has no implementation (no RVA).
c# code to call the methods
public static extern void DoSomething();
public static extern void PROGRESS(ref int PERCENT_COMPLETE, ref int CURRENT_STATUS);
private void ListenMainThread()
int PERCENT_COMPLETE = 0, CURRENT_STATUS = 0;
while (Cond)
PROGRESS(ref PERCENT_COMPLETE, ref CURRENT_STATUS);
Fortran Code:
SUBROUTINE PROGRESS(PERCENT_COMPLETE,CURRENT_STATUS)
!MS$ATTRIBUTES DLLEXPORT, ALIAS:'PROGRESS' :: PROGRESS
USE PROGRESS_DECLARATIONS
IMPLICIT NONE
INTEGER :: CURRENT_STATUS
INTEGER :: PERCENT_COMPLETE
CURRENT_STATUS=FLOAT(IPROGRESS(1))
PERCENT_COMPLETE=FLOAT(IPROGRESS(2))
RETURN
END
Please let me know if i am missing anything while adding another function call to my C# code.
Thank you!
-Chouhan
while (Cond)
Fortran Code:
IMPLICIT NONE
RETURN
END
Thank you!
-Chouhan
You declare current_status and percent_complete as INTEGER
You then set them with the FLOAT() command
This problem pops up whenhever i add a new Routine in Fortran project and try to call from my c# code.
This is the new Fortran Subroutine i added ..
SUBROUTINE RoutineTest(var1)
!MS$ATTRIBUTES DLLEXPORT,ALIAS:'RoutineTest' :: RoutineTest
IMPLICIT NONE
INTEGER :: var1
var1=var1+1
RETURN
END
Whenhever i try to declare this function my c# code(as shown below), the problem popsup..
public static extern void RoutineTest(ref int var1);
IMPLICIT NONE
INTEGER :: var1
var1=var1+1
RETURN
END
I thought you had to use DllImport and "MarshallAs" to call unmanaged code from C#.
Hi Steve,
I already have dllimport in my code and i am able to access a Fortran Routine method from my code. But when i tried to call another routine which is part of the same Fortran solution the problem occurs.
[DllImport(Fort.dll", CallingConvention = CallingConvention.Cdecl)]
i dont know about MarshallAs.
-Chouhan
-Chouhan
I tried to run your solution. I get following error at the function call.
An unhandled exception of type 'System.BadImageFormatException' occurred in CsharpCallsFortran.exe
Additional information: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
I can see that the subroutine accepts 6 arguments, where as we are trying to pass 8 argument.
In my case i have character array in the call, which unmanagedType shuould i use to MarshallAs.
MarshalAs(UnmanagedType.?) for char array..
thank u!
thank u!
If youy are on a 64-bit system you must build the DLL as 64-bits (and I think specify x64 as the target architecture for the C# project. I haven't looked at this project in a while but I had to do that with the VB.NET samples.
I have bulid the solution as 64-bit. It runs perfectly now.
Now i tried to implement MarshallAs in my solution. It gives me following error.
An unhandled exception of type 'System.AccessViolationException' occurred in FortranTest1.exe
Additional information: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Even i tried to create a new solution (a simple fortran application) it gives me the same error.
pls help.
pls help.
Tha Answer to the root problem is,
We should have dllimport statement for each method that we are trying to import from Fortran DLL.
ie.) [DllImport("Dll")
public static extern void SubRout1();
[DllImport("Dll")
public static extern void SubRout2();
[DllImport("Dll")
Topic Options
