29649 Discussions
An internal bug in IFX when using submodule ?
HyLiu
I try to compile a module where a class is defined as
  type, abstract, extends(CSteadySol)::CUnsteadySol
  contains
  procedure::init_solution=>init_solution_Unsteady
  procedure::solve=>solve_Unsteady
  procedure::UpdateTime=>UpdateTime_Unsteady
  end type
all procedures are module procedures and a submodule is used to define the body of there subroutines. But a error returned, as following in the submodule file
D:\FEA\BFREM1_6\FEA\src\temporal_solver\CTemporalSol_smod.f90(814): error #6406: Conflicting attributes or multiple declaration of name.   [CUNSTEADYSOL_INIT]
D:\FEA\BFREM1_6\FEA\src\temporal_solver\CTemporalSol_smod.f90(859): error #6115: A separate interface body must have been declared in the program unit or an ancestor of the program unit for the separate module procedure.   [INIT_SOLUTION_UNSTEADY]
xfortcom: Fatal: There has been an internal compiler error (C0000005).
MarcGrodent
New Contributor III
The error suggests an interface block is missing in your module. The procedures that are implemented in a submodule must be declared in the module by means of an interface. For instance:
interface
  module subroutine init_solution_Unsteady
  end subroutine init_solution_Unsteady
  ![same for the other procedures implemented in the submodule]
end interface
HyLiu
 I use the interface like this, and it works when i use ifort compiler
  interface
  module subroutine init_solution_Unsteady(this, eqsys_, cfg)
  implicit none
  class(CUnsteadySol), target::this
  class(*), target::eqsys_
  type(json_file)::cfg
  end subroutine
  module subroutine solve_Unsteady(this, eqsys_, cfg)
  implicit none
  !class(CEquation_sys)::eq_sys!equation system
  end subroutine
  end interface
HyLiu
But I found that if I declare init_solution_Unsteady as a private function, it works.
MarcGrodent
New Contributor III
Could you please show the exact code of the parent module containing the type definition and the interface block as well as the corresponding submodule (not the whole implementation, just the lines where the submodule and your subroutines are declared)?
HyLiu
This part is in the mod file:
  module CUnSteadySol_mod
  implicit none
  public::CUnsteadySol, CUnsteadySol_
  !public::init_solution_Unsteady ,UpdateTime_Unsteady
  private
  contains
  end type
  interface CUnsteadySol_
  module procedure CUnsteadySol_init
  end interface
  interface
  module subroutine CUnsteadySol_init(this0, eqsys_, cfg)
  implicit none
  class(CTemporalSol)::this0
  !procedure,target::space_integ,SetAux
  end subroutine
  implicit none
  end subroutine
  implicit none
  end subroutine
  module subroutine UpdateTime_Unsteady(this, eqsys_, cfg)
  implicit none
  end subroutine
  end interface
  end module
this part is in the submodule file:
submodule(CUnSteadySol_mod) CUnSteadySol_smod
  contains
  use Cstudy_mod
  use stdlib_strings,only: to_string
  implicit none
  end subroutine
  use Cstudy_mod
  implicit none
  end subroutine
  use stdlib_strings
  use KSP_solver_mod
  use Cstudy_mod
  implicit none
  end subroutine
  use Cstudy_mod
  implicit none
  end subroutine
  end submodule
LitSurfTry
ITS EXAMPLE SAMPLE PROPOSAL HERE (HOW THINGS YOU MUST SIMILAR DO):
  module subroutine init_solution_Unsteady(this, eq_sys, cfg)
  implicit none
class(*), target::eq_sys
  end subroutine
  module subroutine solve_Unsteady(this, eq_sys, cfg)
  implicit none
!class(CUnsteadySol),(eq_sys)::eq_sys!eq_sys
  end subroutine
  end interface
Like or not... since this month everything coding must be more accurate... machines must know what to do more accurately.
