29488 Discussions
Analog of #pragma float_control(precise,on), #pragma fp_contract ( { on | off } ), etc. in FPP
AlexLLE
Does FORTRAN preprocess offers floating point control similar to C/C++?
I need to prevent compiler from rearranging and optimizing a single formula in a source file.
Steve_Lionel
I'll note that those pragmas are specific to Microsoft Visual C/C++ and not the C/C++ language.  Standard Fortran does provide intrinsic modules IEEE_ARITHMETIC, IEEE_EXCEPTIONS and IEEE_FEATURES that provide some level of control. Only the fp_contract pragma is something Fortran doesn't offer.
Intel Fortran DOES have some directives (pragmas) that can control things on a more granular level, including turning FMA on and off, and disabling loop fusion. For a list, see General Compiler Directives (intel.com)
Steve_Lionel
In Fortran, that level of control is not provided. You can specify /fp:strict (-fp-model strict) for that one source file.  Also, have a read through of Improving Numerical Reproducibility in C/C++/Fortran
AlexLLE
Thanks, Steve, for the reply and the link!
It is unfortunate that C/C++ have it and FORTRAN doesn't.
Solutions involving special casing the make process just for one single file
is inelegant and harder to maintain. Disabling optimizations
on the whole source file just for one single formula is not a right approach either.
Is there a plan to add the feature in future releases?
Can/should I submit a feature request?
Ron_Green
There are a lot of directives and compiler options for FP control.
Specifically, for which #pragma do you want a Fortran equivalent?
AlexLLE
#pragma float_control(except, {on|off})
#pragma float_control(precise, {on|off})
#pragma fenv_access({on|off})
#pragma fp_contract({on|off})
See:
https://learn.microsoft.com/en-us/cpp/preprocessor/float-control?view=msvc-170
Steve_Lionel
AlexLLE
Thanks for the references.
Intel icc C++ compiler supports fp_control etc. pragma's too.
https://www.intel.com/content/dam/develop/external/us/en/documents/fp-control-2012-08.pdf
Here we used in our our GPU/CPU code before.
#if defined(__INTEL_COMPILER)
#pragma message("Using float_control pragma")
#pragma float_control(source,on,push)
#endif
__host__ __device__ __inline__
floatlle clfun(cell& c,int sm1,floatlle x,floatlle y){
return CLFUN(c,sm1,x,y);
floatlle clfun_plus_1(cell& c,int sm1,floatlle x,floatlle y){
return CLFUN(c,sm1,x,y) + 1;
#pragma float_control(pop)
#endif
Steve_Lionel
Yes, because icc wants to be compatible with Microsoft C. My point was that these were implementation extensions, not part of the base language.
