Another coarray issue
OP1
New Contributor III
Let's assume I have the two following source files:
MODULE TEST_MODULE
    USE,INTRINSIC :: ISO_FORTRAN_ENV
    IMPLICIT NONE
    INTEGER,ALLOCATABLE :: A(:)[:]
END MODULE TEST_MODULE
and
PROGRAM TEST
    USE TEST_MODULE
    IMPLICIT NONE
    ALLOCATE(A(10)
  • ) END PROGRAM TEST
  • Running the code yields: "forrtl: severe (151): allocatable array is already allocated..."
    Now, if I bundle the module and the program in the same source file, as shown here:
    MODULE TEST_MODULE
        IMPLICIT NONE
    PROGRAM TEST
        USE TEST_MODULE
        IMPLICIT NONE
        ALLOCATE(A(10)
  • then the program runs successfully (well at least it does not crash).
    All this is with IVF 15.0 Update 0 (latest Beta) and VS2013. Any idea? I am trying very hard these days to love Intel coarrays but it's not easy...
    OP1
    New Contributor III
    ... and when I compile from the command line I get an "fortcom: Fatal: There has been an internal compiler error (C0000005). Compilation aborted for TEST.f90 (code 1)" error message. Strange. This is with Version 15.0.0.070 Beta Build 20140530.
    Thanks - we'll take a look at this.
    I can reproduce both problems - thanks. Curiously, it's only in 15.0, not in 14.0. I have escalated this as issue DPD200360242.
    OP1
    New Contributor III
    Thanks Steve!
    I would add that (at least, on my machine) the behavior of the compiler (and the resulting executable) seems to differ whether it is compiled as a Debug or Release version. The Release version triggers an ICE. The Debug version compiles and links; but then the code, when executed, triggers an 'allocatable array already allocated'. This behavior holds for both 32-bit and 64-bit versions.
    This is a very basic functionality (being able to put a coarray in a module!) and therefore this bug is a complete show-stopper, I would say that because of this regression coarrays are not useable with 15.0 for any realistic, non-trivial code.
    [I also suspect that there is something fishy happening with the MPI libraries during the installation/integration of 15.0 with VS2013, although this may be limited to my environment; but I would have expected however that a fresh install of both VS2013 (first) and then the Intel compiler could solve my problems - and this did not]
    Yes, that's what I found. I doubt there is any MPI issue here - it seems to be a generated code problem. The developers are looking at this now.
    A simple workaround for this one - add the SAVE attribute to the coarray in the module. This is harmless as the standard has it given SAVE anyway as a module variable.
    OP1
    New Contributor III
    Thanks Steve - this will do as a stop gap measure. I will declare all my module coarrays with the SAVE attribute and test again.
