29541 Discussions
Another regression in ifort 2021.13.0 oneAPI 24.2
Juergen_R_R
Valued Contributor II
The following code leads to an free invalid pointer exception with the following backtrace:
#0  __pthread_kill_implementation (threadid=<optimized out>, signo=signo@entry=6, no_tid=no_tid@entry=0) at pthread_kill.c:44
#1  0x00007ffff7c8b9b3 in __pthread_kill_internal (signo=6, threadid=<optimized out>) at pthread_kill.c:78
#2  0x00007ffff7c3e646 in __GI_raise (sig=sig@entry=6) at ../sysdeps/posix/raise.c:26
#3  0x00007ffff7c287f3 in __GI_abort () at abort.c:79
#4  0x00007ffff7c29130 in __libc_message (fmt=<optimized out>, fmt@entry=0x7ffff7dbb6a8 "%s\n") at ../sysdeps/posix/libc_fatal.c:150
#5  0x00007ffff7c959f7 in malloc_printerr (str=str@entry=0x7ffff7db91e7 "free(): invalid pointer") at malloc.c:5515
#6  0x00007ffff7c972ac in _int_free (av=<optimized out>, p=<optimized out>, have_lock=0) at malloc.c:4306
#7  0x00007ffff7c99d35 in __GI___libc_free (mem=<optimized out>) at malloc.c:3258
#8  0x000000000041ff2e in for_deallocate_handle ()
#9  0x0000000000406a0b in bloch_vectors_mp_bloch_vector_to_matrix_ ()
#10 0x000000000040575d in bloch_vectors_utibloch_vectors_3_mp_bloch_arbitrary_ ()
#11 0x00000000004043e0 in bloch_vectors_uti_mp_bloch_vectors_3_ ()
#12 0x00000000004041fe in MAIN__ ()
#13 0x00000000004041ad in main ()
still was still working in ifort 2021.10.0 from June 2023.
This is the reproducer:
module kinds
  use, intrinsic :: iso_fortran_env
  use, intrinsic :: iso_c_binding
  implicit none
  private
  integer, parameter :: single    =  4   !  1.. 6 ! real32  ! c_float
  integer, parameter :: double    =  8   !  7..15 ! real64  ! c_double
  public :: single, double
  public :: default
  integer, parameter :: default           = double
 end module kinds
module physics_defs
  implicit none
  private
  integer, parameter, public :: UNDEFINED = 0
  integer, parameter, public:: UNKNOWN = 0
  integer, parameter, public :: SCALAR = 1, SPINOR = 2, VECTOR = 3, &
                                VECTORSPINOR = 4, TENSOR = 5
end module physics_defs
module su_algebra
  use kinds, only: default
  implicit none
  private
  public :: algebra_dimension
  public :: fundamental_dimension
  public :: helicity_value
  public :: helicity_index
  public :: is_cartan_generator
  public :: cartan_index
  public :: cartan_element
  public :: cartan_coeff
  public :: root_index
  public :: root_helicity
  interface
    module function algebra_dimension (s) result (n)
      integer :: n
      integer, intent(in) :: s
    end function algebra_dimension
    module function fundamental_dimension (s) result (d)
      integer :: d
    end function fundamental_dimension
    module function helicity_value (s, i) result (h)
      integer :: h
      integer, intent(in) :: s, i
    end function helicity_value
    module function helicity_index (s, h) result (i)
      integer, intent(in) :: s, h
      integer :: i
    end function helicity_index
    elemental module function is_cartan_generator (s, i) result (cartan)
      logical :: cartan
    end function is_cartan_generator
    elemental module function cartan_index (s, k) result (ci)
      integer :: ci
      integer, intent(in) :: s, k
    end function cartan_index
    module function cartan_element (s, h) result (a)
      real(default), dimension(:), allocatable :: a
    end function cartan_element
    module function cartan_coeff (s, rd) result (a)
      real(default), dimension(:), intent(in) :: rd
    end function cartan_coeff
    module function root_index (s, h1, h2, r) result (ai)
      integer :: ai
      integer, intent(in) :: s, h1, h2
      logical :: r
    end function root_index
    module subroutine root_helicity (s, i, h1, h2, r)
      integer, intent(out) :: h1, h2
      logical, intent(out) :: r
    end subroutine root_helicity
  end interface
end module su_algebra
submodule (su_algebra) su_algebra_s
  use physics_defs, only: SCALAR, SPINOR, VECTOR, VECTORSPINOR, TENSOR
  implicit none
contains
    integer :: n
    n = fundamental_dimension (s) ** 2 - 1
    integer :: d
    d = s
    integer :: h
    integer, dimension(1), parameter :: hh1 = [0]
    integer, dimension(2), parameter :: hh2 = [1, -1]
    integer, dimension(3), parameter :: hh3 = [1,  0, -1]
    integer, dimension(4), parameter :: hh4 = [2,  1, -1, -2]
    integer, dimension(5), parameter :: hh5 = [2,  1,  0, -1, -2]
    h = 0
    select case (s)
    case (SCALAR)
       select case (i)
       case (1:1);  h = hh1(i)
       end select
    case (SPINOR)
       select case (i)
       case (1:2);  h = hh2(i)
       end select
    case (VECTOR)
       select case (i)
       case (1:3);  h = hh3(i)
       end select
    case (VECTORSPINOR)
       select case (i)
       case (1:4);  h = hh4(i)
       end select
    case (TENSOR)
       select case (i)
       case (1:5);  h = hh5(i)
       end select
    end select
    integer :: i
    integer, dimension(0:0), parameter :: hi1 = [1]
    integer, dimension(-1:1), parameter :: hi2 = [2, 0, 1]
    integer, dimension(-1:1), parameter :: hi3 = [3, 2, 1]
    integer, dimension(-2:2), parameter :: hi4 = [4, 3, 0, 2, 1]
    integer, dimension(-2:2), parameter :: hi5 = [5, 4, 3, 2, 1]
    select case (s)
    case (SCALAR)
       i = hi1(h)
    case (SPINOR)
       i = hi2(h)
    case (VECTOR)
       i = hi3(h)
    case (VECTORSPINOR)
       i = hi4(h)
    case (TENSOR)
       i = hi5(h)
    end select
    logical :: cartan
    select case (s)
    case (SCALAR)
    case (SPINOR)
       select case (i)
       case (3);  cartan = .true.
       case default
          cartan = .false.
       end select
    case (VECTOR)
       select case (i)
       case (3,8);  cartan = .true.
       case default
          cartan = .false.
       end select
    case (VECTORSPINOR)
       select case (i)
       case (3,6,15);  cartan = .true.
       case default
          cartan = .false.
       end select
    case (TENSOR)
       select case (i)
       case (3,6,15,24);  cartan = .true.
       case default
          cartan = .false.
       end select
    case default
       cartan = .false.
    end select
    integer :: ci
    integer, dimension(1), parameter :: ci2 = [3]
    integer, dimension(2), parameter :: ci3 = [3,8]
    integer, dimension(3), parameter :: ci4 = [3,6,15]
    integer, dimension(4), parameter :: ci5 = [3,6,15,24]
    select case (s)
    case (SPINOR)
       ci = ci2(k)
    case (VECTOR)
       ci = ci3(k)
    case (VECTORSPINOR)
       ci = ci4(k)
    case (TENSOR)
       ci = ci5(k)
    case default
       ci = 0
    end select
    real(default), parameter :: sqrt2 = sqrt (2._default)
    real(default), parameter :: sqrt3 = sqrt (3._default)
    real(default), parameter :: sqrt10 = sqrt (10._default)
    allocate (a (algebra_dimension (s)), source = 0._default)
    select case (s)
    case (SCALAR)
    case (SPINOR)
       select case (h)
       case (1)
          a(3) =  1._default / 2
       case (-1)
          a(3) = -1._default / 2
       end select
    case (VECTOR)
       select case (h)
       case (1)
          a(8) =  1._default / (2 * sqrt3)
       case (-1)
       case (0)
          a(8) = -1._default / sqrt3
       end select
    case (VECTORSPINOR)
       select case (h)
       case (2)
          a(15) =  1._default / (2 * sqrt2)
       case (-2)
       case (1)
          a(6)  =  1._default / 2
          a(15) = -1._default / (2 * sqrt2)
       case (-1)
          a(6)  = -1._default / 2
       end select
    case (TENSOR)
       select case (h)
       case (2)
          a(24) =  1._default / (2 * sqrt10)
       case (-2)
       case (1)
       case (-1)
       case (0)
          a(24) = -4._default / (2 * sqrt10)
       end select
    end select
    integer :: n
    n = algebra_dimension (s)
    allocate (a (n), source = 0._default)
    select case (s)
    case (SPINOR)
       a(3) = rd(1) - rd(2)
    case (VECTOR)
       a(3) = rd(1) - rd(3)
       a(8) = (rd(1) - 2 * rd(2) + rd(3)) / sqrt3
    case (VECTORSPINOR)
       a(3) = rd(1) - rd(4)
       a(6) = rd(2) - rd(3)
       a(15) = (rd(1) - rd(2) - rd(3) + rd(4)) / sqrt2
    case (TENSOR)
       a(3) = rd(1) - rd(5)
       a(6) = rd(2) - rd(4)
       a(15) = (rd(1) - rd(2) - rd(4) + rd(5)) / sqrt2
       a(24) = (rd(1) + rd(2) - 4 * rd(3) + rd(4) + rd(5)) / sqrt10
    end select
    integer :: ai
    logical :: r
    ai = 0
    select case (s)
    case (SCALAR)
    case (SPINOR)
       select case (h1)
       case (1)
          select case (h2)
          case (-1);  ai = 1
          end select
       end select
    case (VECTOR)
       select case (h1)
       case (1)
          select case (h2)
          case (-1);  ai = 1
          case (0);   ai = 4
          end select
       case (0)
          select case (h2)
          case (-1);  ai = 6
          end select
       end select
    case (VECTORSPINOR)
       select case (h1)
       case (2)
          select case (h2)
          case (-2);  ai = 1
          case (1);   ai = 7
          case (-1);  ai = 11
          end select
       case (1)
          select case (h2)
          case (-1);  ai = 4
          case (-2);  ai = 13
          end select
       case (-1)
          select case (h2)
          case (-2);  ai = 9
          end select
       end select
    case (TENSOR)
       select case (h1)
       case (2)
          select case (h2)
          case (-2);  ai = 1
          case (1);   ai = 7
          case (-1);  ai = 11
          case (0);   ai = 16
          end select
       case (1)
          select case (h2)
          case (-1);  ai = 4
          case (-2);  ai = 13
          case (0);   ai = 20
          end select
       case (-1)
          select case (h2)
          case (-2);  ai = 9
          end select
       case (0)
          select case (h2)
          case (-2);  ai = 18
          case (-1);  ai = 22
          end select
       end select
    end select
    if (ai /= 0 .and. .not. r)  ai = ai + 1
    h1 = 0
    h2 = 0
    r  = .false.
    select case (s)
    case (SCALAR)
    case (SPINOR)
       select case (i)
       case ( 1, 2);  h1 =  1;  h2 = -1;  r = i == 1
       end select
    case (VECTOR)
       select case (i)
       case ( 4, 5);  h1 =  1;  h2 =  0;  r = i == 4
       case ( 6, 7);  h1 =  0;  h2 = -1;  r = i == 6
       end select
    case (VECTORSPINOR)
       select case (i)
       case ( 1, 2);  h1 =  2;  h2 = -2;  r = i == 1
       case ( 4, 5);  h1 =  1;  h2 = -1;  r = i == 4
       case ( 7, 8);  h1 =  2;  h2 =  1;  r = i == 7
       case ( 9,10);  h1 = -1;  h2 = -2;  r = i == 9
       case (11,12);  h1 =  2;  h2 = -1;  r = i ==11
       case (13,14);  h1 =  1;  h2 = -2;  r = i ==13
       end select
    case (TENSOR)
       select case (i)
       case (16,17);  h1 =  2;  h2 =  0;  r = i ==16
       case (18,19);  h1 =  0;  h2 = -2;  r = i ==18
       case (20,21);  h1 =  1;  h2 =  0;  r = i ==20
       case (22,23);  h1 =  0;  h2 = -1;  r = i ==22
       end select
    end select
end submodule su_algebra_s
module bloch_vectors
  use physics_defs, only: UNKNOWN
  implicit none
  private
  public :: bloch_vector_t
  type :: bloch_vector_t
     private
     integer :: spin_type = UNKNOWN
   contains
     generic :: init => bloch_vector_init
     procedure, private :: bloch_vector_init
     procedure :: from_array => bloch_vector_from_array
     procedure :: to_array => bloch_vector_to_array
     procedure :: hel_value => bv_helicity_value
     procedure :: bloch_factor => bv_factor
     procedure :: is_defined => bloch_vector_is_defined
     procedure :: is_polarized => bloch_vector_is_polarized
     procedure :: is_diagonal => bloch_vector_is_diagonal
     procedure :: get_norm => bloch_vector_get_norm
     generic :: init => bloch_vector_init_diagonal
     procedure, private :: bloch_vector_init_diagonal
     generic :: set => bloch_vector_set_diagonal
     procedure, private :: bloch_vector_set_diagonal
     procedure :: to_vector => bloch_vector_to_vector
     generic :: init => bloch_vector_init_matrix
     procedure, private :: bloch_vector_init_matrix
     generic :: set => bloch_vector_set_matrix
     procedure, private :: bloch_vector_set_matrix
     procedure :: to_matrix => bloch_vector_to_matrix
end type bloch_vector_t
  interface
    module subroutine bloch_vector_init (pol, spin_type)
      class(bloch_vector_t), intent(out) :: pol
      integer, intent(in) :: spin_type
    end subroutine bloch_vector_init
    module subroutine bloch_vector_from_array (pol, a)
      class(bloch_vector_t), intent(inout) :: pol
      real(default), dimension(:), allocatable, intent(in) :: a
    end subroutine bloch_vector_from_array
    module subroutine bloch_vector_to_array (pol, a)
      class(bloch_vector_t), intent(in) :: pol
      real(default), dimension(:), allocatable, intent(out) :: a
    end subroutine bloch_vector_to_array
    module function bv_helicity_value (pol, i) result (h)
      integer, intent(in) :: i
      integer :: h
    end function bv_helicity_value
    module function bv_factor (pol) result (f)
      real(default) :: f
    end function bv_factor
    module function bloch_vector_is_defined (pol) result (flag)
      logical :: flag
    end function bloch_vector_is_defined
    module function bloch_vector_is_polarized (pol) result (flag)
      logical :: flag
    end function bloch_vector_is_polarized
    module function bloch_vector_is_diagonal (pol) result (diagonal)
      logical :: diagonal
    end function bloch_vector_is_diagonal
    module function bloch_vector_get_norm (pol) result (norm)
      real(default) :: norm
    end function bloch_vector_get_norm
    module subroutine bloch_vector_init_diagonal (pol, spin_type, rd)
    end subroutine bloch_vector_init_diagonal
    module subroutine bloch_vector_set_diagonal (pol, rd)
    end subroutine bloch_vector_set_diagonal
    module subroutine bloch_vector_to_vector (pol, a)
      real(default), dimension(3), intent(out) :: a
    end subroutine bloch_vector_to_vector
    module subroutine bloch_vector_init_matrix (pol, spin_type, r)
      complex(default), dimension(:,:), intent(in) :: r
    end subroutine bloch_vector_init_matrix
    module subroutine bloch_vector_set_matrix (pol, r)
    end subroutine bloch_vector_set_matrix
    module subroutine bloch_vector_to_matrix (pol, r, only_max_weight)
      complex(default), dimension(:,:), intent(out), allocatable :: r
      logical, intent(in), optional :: only_max_weight
    end subroutine bloch_vector_to_matrix
  end interface
end module bloch_vectors
submodule (bloch_vectors) bloch_vectors_s
  use su_algebra
  implicit none
contains
  function bloch_factor (s) result (f)
    real(default) :: f
    select case (s)
    case (SCALAR)
       f = 0
    case (SPINOR)
       f = 1
    case (VECTOR)
       f = 2 * sqrt (3._default) / 3
    case (VECTORSPINOR)
       f = 2 * sqrt (6._default) / 4
    case (TENSOR)
       f = 2 * sqrt (10._default) / 5
    case default
       f = 0
    end select
  end function bloch_factor
    pol%spin_type = spin_type
    select case (spin_type)
    case (SCALAR,SPINOR,VECTOR,VECTORSPINOR,TENSOR)
       allocate (pol%a (algebra_dimension (spin_type)), source = 0._default)
    end select
    pol%a(:) = a
    if (pol%is_defined ())  allocate (a (size (pol%a)), source = pol%a)
    integer :: h
    h = helicity_value (pol%spin_type, i)
    real(default) :: f
    f = bloch_factor (pol%spin_type)
    logical :: flag
    flag = pol%spin_type /= UNKNOWN
    logical :: flag
    flag = allocated (pol%a)
    logical :: diagonal
    integer :: s, i
    s = pol%spin_type
    diagonal = .true.
    if (pol%is_polarized ()) then
       do i = 1, size (pol%a)
          if (is_cartan_generator (s, i))  cycle
          if (pol%a(i) /= 0) then
             diagonal = .false.
             return
          end if
       end do
    end if
    select case (pol%spin_type)
    case (SPINOR,VECTOR,VECTORSPINOR,TENSOR)
       norm = sqrt (dot_product (pol%a, pol%a))
    case default
       norm = 1
    end select
    call pol%init (spin_type)
    call pol%set (rd)
    integer :: s
    s = pol%spin_type
    select case (s)
       pol%a(:) = cartan_coeff (s, rd) / bloch_factor (s)
    end select
    integer :: s
    s = pol%spin_type
    select case (s)
    case (SPINOR, VECTOR, VECTORSPINOR, TENSOR)
       a = pol%a(1:3) * bloch_factor (s)
    case default
       a = 0
    end select
       call pol%set (r)
    case default
       call pol%init (UNKNOWN)
    end select
    real(default), dimension(:), allocatable :: rd
    integer :: s, d, i, j, h1, h2, ir, ii
    s = pol%spin_type
    select case (s)
       d = fundamental_dimension (s)
       allocate (rd (d))
       do i = 1, d
          rd(i) = r(i,i)
       end do
       call pol%set (rd)
       do i = 1, d
          h1 = helicity_value (s, i)
          do j = i+1, d
             h2 = helicity_value (s, j)
             ir = root_index (s, h1, h2, .true.)
             ii = root_index (s, h1, h2, .false.)
             pol%a(ir) = real (r(j,i) + r(i,j)) / bloch_factor (s)
             pol%a(ii) = aimag (r(j,i) - r(i,j)) / bloch_factor (s)
          end do
       end do
    end select
    integer :: d, s, h0, ng, ai, h, h1, h2, i, j
    logical :: is_real, only_max
    complex(default) :: val
    if (.not. pol%is_polarized ())  return
    s = pol%spin_type
    only_max = .false.
    select case (s)
    case (VECTOR, VECTORSPINOR, TENSOR)
       if (present (only_max_weight))  only_max = only_max_weight
    end select
    if (only_max) then
       ng = 2
       h0 = helicity_value (s, 1)
    else
       ng = algebra_dimension (s)
       h0 = 0
    end if
    allocate (r (d, d), source = (0._default, 0._default))
    do i = 1, d
       h = helicity_value (s, i)
       if (abs (h) < h0)  cycle
       r(i,i) = 1._default / d &
            + dot_product (cartan_element (s, h), pol%a) * bloch_factor (s)
    end do
    do ai = 1, ng
       if (is_cartan_generator (s, ai))  cycle
       call root_helicity (s, ai, h1, h2, is_real)
       i = helicity_index (s, h1)
       j = helicity_index (s, h2)
       if (is_real) then
          val = cmplx (pol%a(ai) / 2 * bloch_factor (s), 0._default, &
               kind=default)
          r(i,j) = r(i,j) + val
          r(j,i) = r(j,i) + val
       else
          val = cmplx (0._default, pol%a(ai) / 2 * bloch_factor (s), &
               kind=default)
          r(i,j) = r(i,j) - val
       end if
    end do
end submodule bloch_vectors_s
module bloch_vectors_uti
  use physics_defs, only: UNKNOWN, SCALAR, SPINOR, VECTOR, VECTORSPINOR, TENSOR
  use su_algebra, only: algebra_dimension, fundamental_dimension, helicity_value
  use bloch_vectors
  implicit none
  private
  public :: bloch_vectors_3
contains
  subroutine bloch_vectors_3 (u)
    integer, intent(in) :: u
    write (u, "(A)")  "* Test output: bloch_vectors_3"
    write (u, "(A)")  "*   Purpose: test Bloch-vector &
         &polarization implementation"
    write (u, "(A)")
    write (u, "(A)")  "* Initialization (pure polarized, arbitrary):"
    write (u, "(A)")  "*   input matrix, transform, display norm, transform back"
    write (u, "(A)")
    write (u, "(A)")  "* s = 0"
    call bloch_arbitrary (SCALAR)
    write (u, "(A)")
    write (u, "(A)")  "* s = 1/2"
    call bloch_arbitrary (SPINOR)
    write (u, "(A)")
    write (u, "(A)")  "* s = 1"
    call bloch_arbitrary (VECTOR)
    write (u, "(A)")
    write (u, "(A)")  "* s = 3/2"
    call bloch_arbitrary (VECTORSPINOR)
    write (u, "(A)")
    write (u, "(A)")  "* s = 2"
    call bloch_arbitrary (TENSOR)
    write (u, "(A)")
    write (u, "(A)")  "* Test output end: bloch_vectors_3"
  contains
    subroutine bloch_arbitrary (s)
      type(bloch_vector_t) :: pol
      complex(default), dimension(:,:), allocatable :: r
      integer :: d
      write (u, *)
      call init_matrix (d, r)
      where (abs (aimag (r)) < 1.e-14_default)  &
           r = cmplx (real(r, kind=default), 0._default, kind=default)
      call write_matrix (d, r)
      call pol%init (s, r)
      write (u, *)
      write (u, 2)  pol%get_norm (), pol%is_diagonal ()
      write (u, *)
      call pol%to_matrix (r)
2     format (1X,F7.4,1X,L1)
    end subroutine bloch_arbitrary
    subroutine init_matrix (d, r)
      integer, intent(in) :: d
      complex(default), dimension(:,:), allocatable, intent(out) :: r
      complex(default), dimension(:), allocatable :: a
      integer :: i, j
      allocate (a (d))
      norm = 0
      do i = 1, d
         a(i) = cmplx (2*i-1, 2*i, kind=default)
         norm = norm + conjg (a(i)) * a(i)
      end do
      a = a / sqrt (norm)
      allocate (r (d,d))
      do i = 1, d
         do j = 1, d
            r(i,j) = conjg (a(i)) * a(j)
         end do
      end do
    end subroutine init_matrix
    subroutine write_matrix (d, r)
      integer :: i, j
      do i = 1, d
         do j = 1, d
            write (u, 1, advance="no")  r(i,j)
         end do
         write (u, *)
      end do
1     format (99(1X,'(',F7.4,',',F7.4,')',:))
    end subroutine write_matrix
  end subroutine bloch_vectors_3
end module bloch_vectors_uti
program main_ut
  use bloch_vectors_uti, only: bloch_vectors_3
  implicit none
  call bloch_vectors_3 (11)
end program main_ut
Ron_Green
@Juergen_R_R we had a fix go into the code branch for the 2025.0 release ( November/December).
It checked out with both my test code and your main_ut.f90 at -O0 and -O2. Note that I did not have to use -fp-model precise
ifx -what -V -O2 -xhost main_ut.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version dev.x.0 Mainline Build 20240717
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
 Intel(R) Fortran 25.0-1144
GNU ld version 2.41-34.fc40
rwgreen@orcsle153:~/quad/q06277330/test2$ ./a.out
Running test: bloch_vectors_1 ... success.
Running test: bloch_vectors_2 ... success.
Running test: bloch_vectors_3 ... success.
Running test: bloch_vectors_4 ... success.
Running test: bloch_vectors_5 ... success.
Running test: bloch_vectors_6 ... success.
Running test: bloch_vectors_7 ... success.
*** Test Summary ***
  Success:
    bloch_vectors_1: initialization
    bloch_vectors_2: pure state (diagonal)
    bloch_vectors_3: pure state (arbitrary)
    bloch_vectors_4: raw I/O
    bloch_vectors_5: massless state (unpolarized)
    bloch_vectors_6: massless state (arbitrary)
    bloch_vectors_7: massless state (vector)
Total   = 7
Success = 7
Failure = 0
*** End of test Summary ***
and at O2 with xhost
ifx -g -O2 -xhost main_ut.f90
  Success:
Total   = 7
Success = 7
Failure = 0
 and my 'invptr.f90' testcase
$ rm -rf a.out ; ifx -O0 -g -traceback invptr.f90 -what -V -stand f23 ; ./a.out
 starting
 ending
Juergen_R_R
By the way, interestingly, this unit test from our code also behaves differently for the ifx 2024.2 compiler from the "classical" ifort as of 2023, Nagfor 7, and gfortran compilers. I still need to understand the details. Shall I submit a separate report on the ifx issue?
Ron_Green
the testcase above is a compiler bug, a regression at that as it first appears in the 2024.2 compiler.  I have done rudimentary triage but have yet to isolate it further.  We did some work on submodules which may be at the root cause but until I am sure, this is just a theory.
For the unit test:  "behaves differently" do you mean the results are different?  at -O0 or at optimization?  can you explain more about what you see with the ifx unit test?
Juergen_R_R
For ifx with -O0, the produced code segfaults, for -O2 it gives a "wrong" result, different than the expected. I will upload a reproducer. The files in ref-output are the expected outputs, the files in err-output are the two tests #3 and #6 that give different results with -O2
(but do not segfault).
Juergen_R_R
And here is the backtrace for this segmentation fault (note again, that this is for ifx now, not ifort):
Program received signal SIGSEGV, Segmentation fault.
bloch_vectors_3::bloch_arbitrary (s=1) at main_ut.f90:4001
4001	           r = cmplx (real(r, kind=default), 0._default, kind=default)
Missing separate debuginfos, use: dnf debuginfo-install libgcc-11.4.1-3.el9.alma.1.x86_64
(gdb) bt
#0  bloch_vectors_3::bloch_arbitrary (s=1) at main_ut.f90:4001
#1  0x0000000000423917 in bloch_vectors_uti::bloch_vectors_3 (u=12) at main_ut.f90:3969
#2  0x000000000041983f in unit_tests@unit_tests_s::test (test_proc=0xb0ec8148e5894855, name=..., description=..., u_log=11, results=..., _name=15, _description=22)
    at main_ut.f90:2825
#3  0x000000000042b75a in bloch_vectors_ut::bloch_vectors_test (u=11, results=...) at main_ut.f90:4379
#4  0x000000000042b9f9 in main_ut::whizard_check (results=...) at main_ut.f90:4420
#5  0x000000000042b869 in main_ut () at main_ut.f90:4410
#6  0x00000000004051ad in main ()
#7  0x00007ffff7829590 in __libc_start_call_main (main=main@entry=0x405190 <main>, argc=argc@entry=1, argv=argv@entry=0x7fffffffd418)
    at ../sysdeps/nptl/libc_start_call_main.h:58
#8  0x00007ffff7829640 in __libc_start_main_impl (main=0x405190 <main>, argc=1, argv=0x7fffffffd418, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>,
    stack_end=0x7fffffffd408) at ../csu/libc-start.c:389
#9  0x00000000004050c5 in _start ()
Juergen_R_R
Here is a bit shorter reproducer with just the single unit test that segfaults (with -O0) and gives a wrong result (with -O2).
Ron_Green
I isolated this down to an assignment whose right-hand side expression contains the combo of CMPLX( REAL( ...), ...)
Bug ID is CMPLRLLVM-59852
Ron_Green
back to the original reproducer, here is a reduced example.  the seg fault is on the assignement
r = cmplx (real(r, kind=8), 0.0_8)   !...this assignment seg faults
contains
  subroutine bloch_vectors_3 ()
    call bloch_arbitrary ()
  contains
    subroutine bloch_arbitrary ()
      complex(8), dimension(:,:), allocatable :: r
      allocate ( r(1,1) )
program main_ut
  implicit none
  print*, "starting"
  call bloch_vectors_3 ()
  print*, "ending"
end program main_ut
Ron_Green
regarding the 2 later cases, I can see the failures.  However, both .f90 files contain the same construct
R is type complex, allocatable, rank 2.  In the first test case it assumes sizes
(1,1), (2,2), (3,3), etc.   Same in these examples?
unwinding the assignment statement: is it your intent to keep the real part of elements in r and set the imaginary parts of r to 0.0?
In any case, this looks 'same as' the original case and my reduced reproducer.  So I'll wait to open a new issue we get resolution to the first and reduced case.  Then I can retest the subsequent cases.  I fully expect they will work once the reproducers are resolved.
Juergen_R_R
Ron, great, thanks for the swift action. Just to make sure: you took care of both issues here (the one for the ifort and the one for ifx), right? I'm not sure it is really the same issue, but at least both stumble over our unit test bloch_vectors_3. That bloch_vectors_6 gets executed correctly by ifort and incorrectly by ifx might be accidental. Let me know if there is anything I can or need to do.
Ron_Green
  Success:
Total   = 7
Success = 7
Failure = 0
  Success:
Total   = 7
Success = 7
Failure = 0
 starting
 ending
