Another simple coarray bug!
OP1
New Contributor III
The Release configuration of the coarray code below will work properly with 17 Update 4... but it will fail to produce the correct output with a Debug configuration (whether 32-bit or 64-bit).
PROGRAM COARRAY_BUG
IMPLICIT NONE
INTEGER :: I
INTEGER :: BB(2)
  • IF (THIS_IMAGE()==1) THEN     BB(1) = 1     BB(2) = 2     DO I=2,NUM_IMAGES()         ! The following assignment is buggy when 'Debug' configuration is used.         ! It works as intended for a 'Release' configuration.         BB(1:2) = BB(1:2)     END DO END IF SYNC ALL WRITE(*,'(A,I2,A,2I2)') 'I am image',THIS_IMAGE(),' and BB = ',BB END PROGRAM COARRAY_BUG
    OP1
    New Contributor III
    Setting "Check Array and String Bounds" to "No" (option /check:[no]bounds) makes the problem disappear with the Debug configuration... but it should not be there in the first place.
    Devorah_H_Intel
    Thank you for the report. I will investigate and let you know the status of this issue.
