Array Viewer - logarithmic scale
tiborkibedi
Is it possible to use logarithmic scale with the Array Viewer?
Intel_C_Intel
I'm afraid not. According to the AV documentation all you can do with axis scalling property is: AxisAutoScale, XScale, AxisScaleFileName, YScale, UseAxisScales, ZScale, that is (for example):
object.YScale [= value]
where value is "a Float expression that indicates how the y-axis scales", I mean a value from 0 to 1, with a remark "You can stretch or shrink graphs in any of these dimensions by making the scaling values larger or smaller, respectively."
Artur
