Due to cost-of-living increases, I decided that family members were only getting integers as presents this season. I used ifort 12.0.1 to help make my shopping lists, but things ended up in chaos...
I gave the missus lots of zeros last year! Looks like I'll be seeing the new year in from the dog-house again...
[fortran]MODULE XMasLists
IMPLICIT NONE
TYPE :: ListType
CHARACTER(7) :: who_is_it_for
INTEGER, ALLOCATABLE :: what_are_they_getting(:)
END TYPE ListType
CONTAINS
SUBROUTINE MakeTheList(the_list)
TYPE(ListType), INTENT(INOUT), ALLOCATABLE :: the_list(:)
ALLOCATE(the_list(0))
! Mum gets a single six.
the_list = [the_list, ListType('OldDuck', [6])]
! Dad gets a five.
the_list = [the_list, ListType('OldMan', [5])]
! A three and a four for the wife
the_list = [the_list, ListType('Missus', [3, 4])]
! A one and a two for the kid
the_list = [the_list, ListType('RugRat', [1, 2])]
END SUBROUTINE MakeTheList
SUBROUTINE PrintTheList(list)
TYPE(ListType), INTENT(IN) :: list(:)
INTEGER :: i
DO i = 1, SIZE(list)
PRINT "('The ',A7,': ',999(I0,:,','))", list(i)%who_is_it_for, &
list(i)%what_are_they_getting
END DO
END SUBROUTINE PrintTheList
END MODULE XMasLists
PROGRAM AllMyFamilyGetsForChristmasIsIntegers
USE XMasLists
IMPLICIT NONE
TYPE(ListType), ALLOCATABLE :: the_list(:)
CALL MakeTheList(the_list)
CALL PrintTheList(the_list)
END PROGRAM AllMyFamilyGetsForChristmasIsIntegers
[/fortran] [plain]H:\\Projects\\xmas-shopping>ifort /check:all /warn:all /standard-semantics integer-list.f90 Intel Visual Fortran Compiler XE for applications running on IA-32, Version 1 2.0.1.127 Build 20101116 Copyright (C) 1985-2010 Intel Corporation. All rights reserved. Microsoft Incremental Linker Version 8.00.50727.762 Copyright (C) Microsoft Corporation. All rights reserved. -out:integer-list.exe -subsystem:console integer-list.obj H:\\Projects\\xmas-shopping>integer-list.exe The OldDuck: 6 The OldMan : 6 The Missus : 0,0 The RugRat : 1,2[/plain]
Hmm- this looks like a regift of a bug we received earlier this year. I'm out of the office this week but will check with our elves when I get back.
Hi Ian and Steve
On my computer (WinXP-Pro 64, VS2005, composer update 1) I get
The OldDuck: 6
The OldMan : 6
The Missus : 6,4
The RugRat : 1,2
Abhi
The OldDuck: 6
The OldMan : 6
The Missus : 6,4
The RugRat : 1,2
Abhi
That's just as wrong, unfortunately...
Another one for your elves... attempts to buy some zero length CHARACTER arrays on the cheap at the post Christmas sales didn't get very far...
[fortran]PROGRAM empty_character_array_constructors
IMPLICIT NONE
INTEGER, PARAMETER :: some_length = 11
TYPE some_type
CHARACTER(some_length), ALLOCATABLE :: some_component(:)
END TYPE some_type
TYPE(some_type), ALLOCATABLE :: some_array(:)
some_array = [ some_type([CHARACTER(LEN=some_length) :: ]) ]
END PROGRAM empty_character_array_constructors
[/fortran] [plain]>ifort /warn:all /check:all /standard-semantics empty-character-array-constructors.f90 Intel Visual Fortran Compiler XE for applications running on IA-32, Version 12.0.1.127 Build 20101116 Copyright (C) 1985-2010 Intel Corporation. All rights reserved. fortcom: Fatal: There has been an internal compiler error (C0000005). compilation aborted for empty-character-array-constructors.f90 (code 1)[/plain]
Hmm - must have been "Bad Santa" that day. Thanks.
Santa's elves tell me that the first problem, with the integer gifts, is fixed in 12.0 Update 2, and I checked the list to be sure. The second problem, with the empty array in the constructor, has been entered onto the "naughty" list as DPD200165369.
Steve,
Are you absolutely sure that the first problem, the one with integer gifts, was corrected? I have just tried it out and and I'm getting wrong answers in Fortran Composer 12 Update 2.
Pedro
Pedro
Oops. The results are better in Update 2 but not completely correct. Thanks for the second look.
The OldMan got a duplicate gift.
[plain]c:Projects>ifort /standard-semantics gifts.f90 Intel Visual Fortran Compiler XE for applications running on IA-32, Version 1 2.0.2.154 Build 20110112 Copyright (C) 1985-2011 Intel Corporation. All rights reserved. Microsoft Incremental Linker Version 10.00.30319.01 Copyright (C) Microsoft Corporation. All rights reserved. -out:gifts.exe -subsystem:console gifts.obj c:Projects>gifts.exe The OldDuck: 6 The OldMan : 6 The Missus : 3,4 The RugRat : 1,2[/plain]
Steve,
Actually I have different results:
Only the last family member is correct... Much worse than yours. I've taken a look and when "MakeTheList" return the data get corrupted. Actually inside the subroutine "MakeTheList" everything is right (until the return). Hope this helps.
Pedro
[bash]------ Build started: Project: DerivedTypesError, Configuration: Debug Win32 ------ Compiling with Intel Visual Fortran Compiler XE 12.0.2.154 [IA-32]... main.f90 Linking... The OldDuck: -572662307 The OldMan : -572662307 The Missus : -842150451,-842150451 The RugRat : 1,2[/bash]
Pedro
My guess is that you did not add /standard-semantics or /assume:realloc_lhs. One of these is required to make this program work at all.
Steve,
The results I shown to you are compiled with the /standard-semantic switch. I'm aware that this is very important. One more thing, if a compile in Release x64 I get the same answer as you. But this is the only configuration that does the same answer as yours.
Pedro
Pedro
The internal compiler error is expected to be fixed in update 3. The wrong result is still being worked on and is issue DPD200166796.
