Array constructors
IanH
Zero sized array constructors for derived types used to work, didn't they?  They syntax for them appears to be in the compiler docs.
[fortran]PROGRAM WhereDidZeroSizedArrayConstructorsGo
  IMPLICIT NONE
  TYPE :: my_type
  END TYPE my_type
  TYPE(my_type), ALLOCATABLE :: array(:)
  array = [ my_type :: ]
  PRINT *, SIZE(array)
END PROGRAM WhereDidZeroSizedArrayConstructorsGo
[/fortran]
[plain]>ifort /check:all /warn:all /standard-semantics ArrayConstructors.f90
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 13.0.1.119 Build 20121008
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.
ArrayConstructors.f90(8): error #5082: Syntax error, found '::' when expecting one of: , (/ : ]
ArrayConstructors.f90(8): error #6478: A type-name must not be used as a variable.   [MY_TYPE]
compilation aborted for ArrayConstructors.f90 (code 1)[/plain]
Or am I imagining things?  I would have sworn that they were in active use in our code base, but now I can't find any examples.
Yours in deluded confusion,
IanH
We don't yet support this with derived types - it's already on our list. We do support it with intrinsic types, for example: [integer::]
