Array indexing with assumed shape
Andrew_Smith
Valued Contributor I
F95 gave us assumed-shape arrays which are great.
But we nearly alway need to compute the size to do anything with them.
If I want the last element for instance.
So I was wondering, has there been any thoughts for a Future language development (F201x) to add some king of relative indexing.
maybe:
real, intent(in) :: arr(:)
real x, z(2)
x = arr(>1) !Last element
x = arr(<1) !First element
z = arr(>2:2) !Last two elements with stride two
jimdempseyatthecove
Use LBOUND and UBOUND
x = arr(UBOUND(arr)) !Last element
x = arr(LBOUND(arr)) !First element
z = arr(UBOUND(arr)-2:UBOUND(arr):2) !Last two elements with stride two
Jim Dempsey
John4
As Jim Dempsey suggested, there are already intrinsic functions that do just what you want (although not in the fancy way you might expect).
The LBOUND/UBOUND functions return an array of indices by default. Which means, as an example, that the result of array(UBOUND(array)) is not a scalar but a slice.
If you specify the dimension (as a second argument), then the result of LBOUND/UBOUND is scalar.
If you want, you can simplify things a little bit by providing your own wrappers, as in the example below.
[fortran]implicit none
integer :: i, N = 13
real, allocatable :: a(:)
allocate (a(N))
a = [real :: (i, i = 1, N)]
print *, 'first: ', a(LBOUND(a))
print *, 'last: ', a(UBOUND(a))
print *, 'last two, etc.:', a(UBOUND(a,1)-2::2)
print *
print *, 'first: ', first(a)
print *, 'last: ', last(a)
print *, 'last two, etc.:', rstride(a, 2)
print *, 'last three, etc.:', rstride(a, 3)
contains
    pure function first(a) result(x)
        real :: x
        real, intent(IN) :: a(:)
        x = a(LBOUND(a,1))
    end function
    pure function last(a) result(x)
        real :: x
        x = a(UBOUND(a,1))
    end function
    pure function rstride(a, s) result(x)
        integer, intent(IN) :: s
        real :: x(s)
        x = a(UBOUND(a,1) - s * (s - 1)::s)
    end function
end
[/fortran]
jimdempseyatthecove
John, thanks for pointing out my error of ommission of the ",1". I got sloppy there. The compiler would have caught this quickly.
Jim
