Array problem
Kate_Johnson
I am using the following code for random permutations:
    subroutine rperm(nsim, IPERM1)
    integer, intent(in) :: nsim
    integer, dimension(:), intent(out) :: IPERM1
    integer :: mynumber, i, j, k
    real, dimension(nsim) :: rand2
    call random_number(rand2)
    IPERM1= 0
    do i=1,nsim
    print*, 'HEREHEREHERE: i=', i
        mynumber=1
        do j=1,nsim
            if (rand2(i) > rand2(j)) then
                mynumber = mynumber+1
            end if
        end do
        if (i>1) then
            do k=1,i-1
                if (rand2(i) <= rand2(k) .and. rand2(i) >= rand2(k)) then
                end if
            end do
c
        end if
        print*, 'RPERM WORKS HERE'
        IPERM1(i) = mynumber
    end do
    return
    end subroutine rperm
However, it is getting stuck at the line:         IPERM1(i) = mynumber           and exits the subroutine.
Why is this happening?
IanH
How are you calling the procedure?  Does it have an explicit interface?
(Is the argument nsim redundant given the size of the IPERM1 argument is available inside the procedure?)
TimP
I'm guessing you don't have an explicit interface, and so iperm1(:) must be assumed size.  Otherwise, as Ian hinted, size(iperm1) would be defined, and nsim > size(iperm1) could be checked to detect an obvious problem.  In any case, violating that condition would make behavior unpredictable.
If iperm1 is meant to have dimension(nsize), writing it that way and invoking ifort interface checking would give you an automatic indication of the violation.
Kate_Johnson
Got it.  I needed to declare it's size. Thanks
