29647 Discussions
Assign allocated array to other allocatable array
Paweł_J_
I've got two codes, which I want to combine. In one code I've got type:
  TYPE, PUBLIC ::m_type
    INTEGER :: m,
    REAL ( KIND( 1.0D+0 ) ), ALLOCATABLE, DIMENSION(:) :: val
  END TYPE
and subroutine which uses this type as an input:
   subroutine sub(m)
      type(m_type), intent(in) :: matrix
   end subroutine
In the second code, which calls the subroutine sub(), I have already allocated array, let say x(:), and I don't want to allocate once more memory for m%val, just for copying data, because size of x(:) is huge. Is there any way to assign m%val with values of x(:) without allocating additional memory? In C pointer will do the trick, but I don't know how I could use it here. I dont want to change subroutine sub(), because it will cause changes not only in my part of the code.
Any ideas?
mecej4
See if MOVE_ALLOC can be made to do the work for you.
jimdempseyatthecove
Fortran has pointers
module m_mod
  INTEGER :: m,
  REAL ( KIND( 1.0D+0 ) ), ALLOCATABLE, POINTER, DIMENSION(:) :: val
END TYPE
end module m_mod
real, kind(1.0D+0), allocatable, target :: x(:)
Allocate(x(isHuge))
call sub(m)
subroutine sub(m)
use m_mod
type(m_type) :: m
m%val => x ! or x(from:to)
Your post was not clear as to if sub were initializing m%val or using. The above shows part of initializing.
*** Just as in C/C++, it is your responsibility to assure that the underlying x is not deallocated (or reallocated) during the lifetime of pointers pointing to (portions of) it.
Jim Dempsey
