29648 Discussions
Assign value to variables in debugger
tmcole
How do I assign a value to a variable in the CVF6.6 debugger? This is a classic example of why HTML help files are sometimes worse than useless.
ArturGuzik
Valued Contributor I
presumably you mean something else (far more complicated) but a simple assigning (recalculating) of a new value goes like this:
1. QuickWatch
2. click recalculate or click on the field Value
3. change value as required
A.
Jugoslav_Dujic
Valued Contributor II
...or, if you need to do it frequently, you can do more or less the same
in the Watch window.
Jugoslav
